My 3.3L Subie Conversion Thread, Got me some 914rubber stuff |
Chris H. |
Dec 27 2012, 11:02 AM
Senior Member Group: Members Posts: 4,031 Joined: 2-January 03 From: Chicago 'burbs Member No.: 73 Region Association: Upper MidWest |
Finally starting the thread. First, I never would have done this if it weren't for several of you helping me out, especially Ian at:
Cold Water Conversions Ian tolerated dozens of questions from me as I decided which way to go. Thanks again! Here is the candidate (or victim, depending on what side of the fence you are on): A 1975 1.8L with California Emissions...I've had it for almost 11 years. During that time I have logged about 2800 miles on it. I decided to swap it out for a modern drive train so my daughter could drive it so I started looking for a 2.2L Subie and a 2WD auto trans. This setup CAN be made to work with a custom hanger, but it's not a very exciting trans. Think early '90's Camry or Corolla acceleration. I'm sure it could be re-geared but an Audi trans would probably be a much better option. Then I found and SVX for cheap and changed directions entirely. Looks like my kid will be learning to drive a 5 speed Subie! So far I have: Strong running SVX engine 2006 WRX trans purchased from NASIOC If you don't feel like chasing this stuff down Ian will source it for you. Next up I'll post the highlights of the SVX strip-down and note some of the pitfalls, valuable parts, and stuff to be careful not to break! Any feedback, comments, questions, concerns are welcome. I want to do it right. |
a914622 |
Jan 27 2013, 12:28 AM
Member Group: Members Posts: 316 Joined: 12-August 10 From: northwest Member No.: 12,048 Region Association: Pacific Northwest |
Yes the intake can be flipped around, but the injector wiring needs to stay the same. Thats what im working on now. I think a thin toyota or mazda alt will do the trick in place of the power steering pump. Still working on it. The coolant hoses to the throtle body need to be in place for proper cold start.
I am going to try to use the stock intake hoses out to the air sensor. I have seen the 2.2 of the same year react to the shortening the intakes on the vanagons. But i was just reading about the hack for the ecus so injector timing could be shortened if needed. Iv eyeballed the 2 radiator idea but with out hacking up the front body lines i cant see it. FYI the audi 4000 radiator fits almost perfect in the front. jcl |
Lo-Fi Version | Time is now: 2nd June 2024 - 03:03 AM |
