No turn signals, Stumped |
LotusJoe |
Jan 26 2013, 04:22 PM
Europa Twink Driver Group: Members Posts: 406 Joined: 30-November 09 From: Southern California Member No.: 11,085 Region Association: Southern California |
I'm having an issue with the turn signals...They don't work. The emergency flashers work fine. The parking brake light works fine as well. I mention that because my understanding is it uses the same flasher relay. I took the turn signal switch out of the column and tested it on the bench and it shows proper continuity for left and right. No shorts, No blown fuses. At this point I'm stumped. (IMG:style_emoticons/default/confused24.gif) Any thoughts on where to go from here? This is a '74 completely stock wiring nothing has be molested.
TIA |
904svo |
Jan 26 2013, 04:50 PM
904SVO Group: Members Posts: 1,118 Joined: 17-November 05 From: Woodstock,Georgia Member No.: 5,146 |
Do you mean they come on and don't flash? If thats your problem you have the wrong bulbs installed or one of the front side marker bulbs are burn out. If you are using a stock flasher thats the way it was design to let you know a bulb was burn out.
LotusJoe |
Jan 27 2013, 05:07 PM
Do you mean they come on and don't flash? If thats your problem you have the wrong bulbs installed or one of the front side marker bulbs are burn out. If you are using a stock flasher thats the way it was design to let you know a bulb was burn out. But all 4 flash when the emergency flasher switch is pulled?? Also, the parking lights come on when the key is off. If I turn the left blinker on with the key off, the left parking lights come on; and the same with when I put the right turn signal on. However I will check the bulbs. Thanks |
Lo-Fi Version | Time is now: 9th June 2024 - 01:51 PM |
