No turn signals, Stumped |
LotusJoe |
Jan 26 2013, 04:22 PM
Europa Twink Driver Group: Members Posts: 406 Joined: 30-November 09 From: Southern California Member No.: 11,085 Region Association: Southern California |
I'm having an issue with the turn signals...They don't work. The emergency flashers work fine. The parking brake light works fine as well. I mention that because my understanding is it uses the same flasher relay. I took the turn signal switch out of the column and tested it on the bench and it shows proper continuity for left and right. No shorts, No blown fuses. At this point I'm stumped. (IMG:style_emoticons/default/confused24.gif) Any thoughts on where to go from here? This is a '74 completely stock wiring nothing has be molested.
TIA |
904svo |
Jan 27 2013, 05:37 PM
904SVO Group: Members Posts: 1,118 Joined: 17-November 05 From: Woodstock,Georgia Member No.: 5,146 |
Most people forget that there is 2 bulbs per side for a total of 8 bulbs. Front side fender light and parking light ( 2 bulbs) and the same for the rear.
LotusJoe |
Jan 27 2013, 06:22 PM
Most people forget that there is 2 bulbs per side for a total of 8 bulbs. Front side fender light and parking light ( 2 bulbs) and the same for the rear. My front turn buckets only have a place for one bulb a 1157 (IMG:style_emoticons/default/confused24.gif) |
Lo-Fi Version | Time is now: 9th June 2024 - 09:40 PM |
