Proud New Owner, I got to enjoy this beautiful girl for a week before I had a starting issue. looking for help with any diagnostic |
wolfeman1727 |
Jan 23 2013, 11:45 PM
Newbie Group: Members Posts: 8 Joined: 4-November 12 From: Stockton, CA Member No.: 15,113 Region Association: Central California |
Hi all,
I am the ecstatic new owner of a slightly neglected 1973 914, 1.7 model which someone has put a 2.0 in. I got the car with first gear problems and ended up having to take apart the tranny and replace the first gear synchro and dogteeth... which I did myself successfully with out terrible difficulty. I got to Drive this sweet little thing around for about a week and the engine sputtered and died on me. It doesn't get gas -replaced the fuel pump -replaced the filter still no avail The leads in the fuel pump plug read a laughable .2 volts when the ignition is on and the engine turned over. Im not getting the power -replaced relay -cleaned all connections on the regulator plate Im getting 12 volts across the leads attached to the relay, but the relay isnt closing my circuit. Any Ideas?? I miss driving the darn thing! (IMG:style_emoticons/default/pray.gif) |
wolfeman1727 |
Jan 28 2013, 10:29 AM
After much touching, unplugging, testing It started right up...
We bypassed the relay to test the pump, which worked beautifully... and then re- installed the relay...and the dammed thing worked. I'm back on the road for now (IMG:style_emoticons/default/driving.gif) Thanks guys! (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 9th June 2024 - 06:39 AM |
