dry sump plumbing |
dry sump plumbing |
hedfurst |
Jan 28 2013, 05:49 PM
Member Group: Members Posts: 99 Joined: 9-March 03 From: S. Mississippi Member No.: 406 |
Question for those of you who have dry-sumped your 4-cylinder cars.
What is the tank volume everyone's using and what are you doing to keep it from draining into the crank-case when the motor isn't running? Thanks Fred |
ChrisFoley |
Jan 28 2013, 07:04 PM
I am Tangerine Racing Group: Members Posts: 7,933 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
3 gallon capacity is perfect.
If the bottom of the tank is level with the bottom of the engine there will be no issues with the engine overfilling with oil at rest. f the tank is far above the engine sump you will need a special check valve. |
hedfurst |
Jan 28 2013, 09:05 PM
3 gallon capacity is perfect. If the bottom of the tank is level with the bottom of the engine there will be no issues with the engine overfilling with oil at rest. f the tank is far above the engine sump you will need a special check valve. Where is your tank? My plumbing recommendations are that the tank-outlet be 200mm above the pump-inlet. I was looking at a 8quart tank-planned on putting it under the rear deck. |
Lo-Fi Version | Time is now: 28th May 2024 - 12:52 PM |
