dry sump plumbing |
dry sump plumbing |
hedfurst |
Jan 28 2013, 05:49 PM
Member Group: Members Posts: 99 Joined: 9-March 03 From: S. Mississippi Member No.: 406 |
Question for those of you who have dry-sumped your 4-cylinder cars.
What is the tank volume everyone's using and what are you doing to keep it from draining into the crank-case when the motor isn't running? Thanks Fred |
hedfurst |
Jan 29 2013, 08:50 PM
How is the case having no bypass/relief beneficial?
ChrisFoley |
Jan 29 2013, 09:49 PM
I am Tangerine Racing Group: Members Posts: 7,933 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
How is the case having no bypass/relief beneficial? A pressure limiting valve of some kind is needed. You don't really ever want the oil pressure to exceed 80 psi. Doug's is incorporated in his filter adapter. I use an adjustable unit made by Parker (fluid controls), screwed into the side of the crankcase. An external relief valve routes the excess oil back to the dry sump tank rather than back into the engine sump as the stock relief valve does. |
Lo-Fi Version | Time is now: 28th May 2024 - 12:56 PM |
