draganc |
Senior Member ![]() ![]() ![]() Group: Members Posts: 725 Joined: 2-November 09 From: central new jersey Member No.: 11,000 Region Association: North East States ![]() |
Just wanted to share my experience with a 3M "Lens Renewal System" aka headlight polish/cleaner. I'm sure there other products out there but this worked very well.
![]() The actual headlight looked worse than on the before picture, very yellowish. ![]() Take your time, read the instructions AND follow them. Don't rush and try to do all the lights with just one set. If the lights are very yellow, use a second set. ![]() Again, the after picture doesn't do justice of the real condition. The headlights look as good as new!! Took me about 45min per side. Well worth for the looks and better light output. Hope this info helped. dc PS: Double tape the area around the lights, in particular corners and edges!! |
rhodyguy |
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,248 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch ![]() |
"just about"...so 2 trips to perp boys?
k |
draganc |
"just about"...so 2 trips to perp boys? k nope, one kit did both sides! during the application, i would have felt better if i had another set - which i would have used, just to insure that the yellow-ish is removed. i have used another cheap kit (forgot the name) and i split the material between the left and right and it looked like a$$. my take is that it is cheaper to use a kit per side than driving back and forth. |
Lo-Fi Version | Time is now: 1st July 2025 - 03:09 PM |
