Brake Pedal Feel - Need some help, after bleeding ?? Its kinda soft. |
913B |
Feb 1 2013, 07:45 PM
Senior Member Group: Members Posts: 847 Joined: 25-April 05 From: South Bay/SoCal Member No.: 3,983 Region Association: None |
Is it suppose to feel hard on the first push. The pedal goes almost all the way down, then the 2nd and 3rd pump the pedal feels hard, but if I wait a few seconds the hard pedals goes away ?? Is this normal for an early 71 with 19mm MC or do I still have air in the system. I bleed it with the Motive Power bleeder and manual bleeding it with the speed bleeders. Is the problem with the speed bleeders ? I recently rebuilt all the calipers and install new lines, no leaks, but the MC is used though.
Let me know your experiences fellas ? Ted |
injunmort |
Feb 1 2013, 08:00 PM
Senior Member Group: Members Posts: 1,024 Joined: 12-April 10 From: sugarloaf ny Member No.: 11,604 Region Association: North East States |
make sure you are not leaking anywere first. then you can crack all the bleeders and top off m/c. let it sit that way overnight. close the bleeders and bleed starting at the caliper furthest away from master cylinder { right rear wheel first}}. i have my wife pump the brakes while i do the bleeders.work your way around, left rear, right front, left front. make sure you keep an eye on fluid level in resevoir. by the time you are done you should have a firm, steady pedal, no air inthe lines.
Lo-Fi Version | Time is now: 9th June 2024 - 03:54 PM |
