dry sump plumbing |
dry sump plumbing |
hedfurst |
Jan 28 2013, 05:49 PM
Member Group: Members Posts: 99 Joined: 9-March 03 From: S. Mississippi Member No.: 406 |
Question for those of you who have dry-sumped your 4-cylinder cars.
What is the tank volume everyone's using and what are you doing to keep it from draining into the crank-case when the motor isn't running? Thanks Fred |
mrbubblehead |
Jan 28 2013, 08:34 PM
Twodollardoug Group: Members Posts: 1,155 Joined: 17-December 10 From: calimesa ca. Member No.: 12,492 Region Association: Southern California |
Mine holds close to 10qts with a filter change. I bought an electronic valve to keep the oil from draining back into the sump but never installed it. My sump sits on the engine shelf so its above the case. mine leaks "maybe" a qt a week. And I run synthetic 30wt. I think it all depends on the tolerances of the oil pump.
hedfurst |
Jan 28 2013, 09:06 PM
Mine holds close to 10qts with a filter change. I bought an electronic valve to keep the oil from draining back into the sump but never installed it. My sump sits on the engine shelf so its above the case. mine leaks "maybe" a qt a week. And I run synthetic 30wt. I think it all depends on the tolerances of the oil pump. do you mind telling me where you got your talk? |
mrbubblehead |
Jan 28 2013, 10:09 PM
Mine holds close to 10qts with a filter change. I bought an electronic valve to keep the oil from draining back into the sump but never installed it. My sump sits on the engine shelf so its above the case. mine leaks "maybe" a qt a week. And I run synthetic 30wt. I think it all depends on the tolerances of the oil pump. do you mind telling me where you got your talk? Fred, I custom made my tank. Racer Chris was instrumental with my dry sump system. I didnt follow the conventional plumbing routing. I feel I improved upon it. There are many ways to do the system. And that depends on what oil pump you use. Have you decided on a pump yet? My Tank (IMG:http://www.914world.com/bbs2/uploads_offsite/i722.photobucket.com-12492-1359432589.1.jpg) |
hedfurst |
Feb 2 2013, 08:47 PM
Mine holds close to 10qts with a filter change. I bought an electronic valve to keep the oil from draining back into the sump but never installed it. My sump sits on the engine shelf so its above the case. mine leaks "maybe" a qt a week. And I run synthetic 30wt. I think it all depends on the tolerances of the oil pump. do you mind telling me where you got your talk? Fred, I custom made my tank. Racer Chris was instrumental with my dry sump system. I didnt follow the conventional plumbing routing. I feel I improved upon it. There are many ways to do the system. And that depends on what oil pump you use. Have you decided on a pump yet? My Tank (IMG:http://www.914world.com/bbs2/uploads_offsite/i722.photobucket.com-12492-1359432589.1.jpg) What are the other structures on top of your tank near the firewall? |
Lo-Fi Version | Time is now: 28th May 2024 - 12:58 PM |
