fuel pump wiring, electical novice! |
malcolm2 |
Feb 4 2013, 08:10 PM
Advanced Member Group: Members Posts: 2,747 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States |
I admit that I am out of my league when it comes to electical wiring, theory, and reading diagrams, so I have a question....
I am going thru the wiring on my 75 L-jet. I replaced the OEM fuse box and just kinda kept going. I towed this car home 18 months ago, so I have no idea what works and what does not. Anyway, I see a heavier gauge wire in the gas tank area (tank is out). The wire is Black with a Red stripe. I followed it back to the relay board and figured it has something to do with the fuel pump. The color diagram on PP leads me to the FP relay and then on to a white wire labeled 12. The PO has the fuel pump wired directly to the coil with a heavy red wire that I know was not OEM. And this mystery BLK/RED wire is cut on the Fuel Pump end. Any ideas why the PO did this? Will I need a new relay, maybe? Thoughts anyone? Thanks, Clark |
Spoke |
Feb 4 2013, 09:14 PM
Jerry Group: Members Posts: 6,991 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
Where is the fuel pump located now? Under the gas tank or in the engine compartment?
The wire you successfully traced back to the relay board is for the fuel pump when it is located under the gas tank. The positive terminal of the fuel pump goes to the black/red wire. the negative terminal of the fuel pump goes to chassis ground. |
Lo-Fi Version | Time is now: 9th June 2024 - 07:38 AM |
