fuel pump wiring, electical novice! |
malcolm2 |
Feb 4 2013, 08:10 PM
Advanced Member Group: Members Posts: 2,745 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States |
I admit that I am out of my league when it comes to electical wiring, theory, and reading diagrams, so I have a question....
I am going thru the wiring on my 75 L-jet. I replaced the OEM fuse box and just kinda kept going. I towed this car home 18 months ago, so I have no idea what works and what does not. Anyway, I see a heavier gauge wire in the gas tank area (tank is out). The wire is Black with a Red stripe. I followed it back to the relay board and figured it has something to do with the fuel pump. The color diagram on PP leads me to the FP relay and then on to a white wire labeled 12. The PO has the fuel pump wired directly to the coil with a heavy red wire that I know was not OEM. And this mystery BLK/RED wire is cut on the Fuel Pump end. Any ideas why the PO did this? Will I need a new relay, maybe? Thoughts anyone? Thanks, Clark |
timothy_nd28 |
Feb 4 2013, 09:17 PM
Advanced Member Group: Members Posts: 2,299 Joined: 25-September 07 From: IN Member No.: 8,154 Region Association: Upper MidWest |
I'm guessing that he aborted the Ljet FI system, and installed a carb low pressure fuel pump. The dual relay thats mounted near the ECU brain, controls the fuel pump.
Lo-Fi Version | Time is now: 1st June 2024 - 07:53 PM |
