> Fan Housing Vibration....
lennyhope
post Feb 8 2013, 12:01 PM
Region Association: England
I am a mechanical novice and after changing seals and the fan I have now re-installed and now find a vibration from the fan housing..!!! I was careful to tighten up as per Haynes etc. I did however replace fan for an earlier fan with conical middle and allen bolts....Would that make a difference?
yeahmag
post Feb 8 2013, 12:59 PM
The fan is typically part of the rotating assembly balance job. If you swapped out fans you probably introduced and imbalanced part in to the rotating assembly. Put the old fan back and see if it goes away.
- Lo-Fi Version Time is now: 1st May 2026 - 11:04 PM
