Full Version: Fan Housing Vibration....
lennyhope
I am a mechanical novice and after changing seals and the fan I have now re-installed and now find a vibration from the fan housing..!!! I was careful to tighten up as per Haynes etc. I did however replace fan for an earlier fan with conical middle and allen bolts....Would that make a difference?
yeahmag
The fan is typically part of the rotating assembly balance job. If you swapped out fans you probably introduced and imbalanced part in to the rotating assembly. Put the old fan back and see if it goes away.
ArtechnikA
with luck, it's just sucked in a paper towel you forgot about...
lennyhope
QUOTE(ArtechnikA @ Feb 8 2013, 08:31 PM) *
Taken tin ware off and alternator.....Seems i have the fan located wrong
TheCabinetmaker
Please elaborate on " located wrong"
914itis
euro911
A lot of folks take their fans apart (remove the pulley from the fan to clean, blast and paint) and put it back together without realizing that it was originally balanced at the factory. I've been guilty of doing that ... once shades.gif
If one wants to take a fan apart, always mark both pieces beforehand so it goes back together in the same exact position. Maybe that's what happened to the 'new' fan you installed confused24.gif
yeahmag
It should have a dowel and key to keep it indexed. Not sure how that happened...
Kirmizi
QUOTE(euro911 @ Feb 8 2013, 04:40 PM) *
Mike
