| lennyhope |
Feb 8 2013, 12:01 PM
Member ![]() ![]() Group: Members Posts: 168 Joined: 2-November 11 From: prescot Member No.: 13,736 Region Association: England |
I am a mechanical novice and after changing seals and the fan I have now re-installed and now find a vibration from the fan housing..!!! I was careful to tighten up as per Haynes etc. I did however replace fan for an earlier fan with conical middle and allen bolts....Would that make a difference?
| yeahmag |
Feb 8 2013, 12:59 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,481 Joined: 18-April 05 From: Pasadena, CA Member No.: 3,946 Region Association: Southern California
The fan is typically part of the rotating assembly balance job. If you swapped out fans you probably introduced and imbalanced part in to the rotating assembly. Put the old fan back and see if it goes away.
| ArtechnikA |
Feb 8 2013, 02:31 PM
rich herzog ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,390 Joined: 4-April 03 From: Salted Roads, PA Member No.: 513 Region Association: None |
with luck, it's just sucked in a paper towel you forgot about...
| lennyhope |
Feb 8 2013, 04:58 PM
| TheCabinetmaker |
Feb 8 2013, 06:25 PM
I drive my car everyday ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,377 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
Please elaborate on " located wrong"
| 914itis |
Feb 8 2013, 06:31 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,892 Joined: 9-October 10 From: New York City Member No.: 12,256 Region Association: North East States |
| euro911 |
Feb 8 2013, 06:40 PM
Retired & living the dream. God help me if I wake up! ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,937 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California
A lot of folks take their fans apart (remove the pulley from the fan to clean, blast and paint) and put it back together without realizing that it was originally balanced at the factory. I've been guilty of doing that ... once (IMG:style_emoticons/default/shades.gif)
If one wants to take a fan apart, always mark both pieces beforehand so it goes back together in the same exact position. Maybe that's what happened to the 'new' fan you installed (IMG:style_emoticons/default/confused24.gif) |
| yeahmag |
Feb 8 2013, 06:44 PM
It should have a dowel and key to keep it indexed. Not sure how that happened...
| Kirmizi |
Feb 8 2013, 07:52 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 836 Joined: 12-February 06 From: Wyoming, US Member No.: 5,568 Region Association: None |
A lot of folks take their fans apart (remove the pulley from the fan to clean, blast and paint) and put it back together without realizing that it was originally balanced at the factory. I've been guilty of doing that ... once (IMG:style_emoticons/default/shades.gif) If one wants to take a fan apart, always mark both pieces beforehand so it goes back together in the same exact position. Maybe that's what happened to the 'new' fan you installed (IMG:style_emoticons/default/confused24.gif) Did you have trouble setting your timing afterwards? (IMG:style_emoticons/default/blink.gif) Mike |
Lo-Fi Version | Time is now: 1st May 2026 - 09:14 PM |
