> Newbie with a few questions!, Car don't want to fire back up after running for awhile.
Noodles
post Feb 9 2013, 04:55 PM
Went for a drive today since I finally got a day off on a weekend that it's not raining. (IMG:style_emoticons/default/driving.gif) Had a blast for a good 45min cruising around some back roads. While driving It backfired a few times and had a slight hesitation from coming from a complete stop. It also died once or twice but it didn't have to bad an issue starting back up.
When I got back home it sat for maybe 2 min and then when I tried to move it, it didn't want to start. It was turning over just fine just didn't want to fire up.
It's a 1.8 fuel injected 75. Was told when I bought it, it was upgraded to a 2.0 but I have no proof of that. I also have a huge hole in my muffler which brings me to my next question. I took a muffler from my 72 parts car and was wondering if I can just bolt it right on to replace it.
Any help on where I should start looking for my problem would be much appreciated. I'm sure I'm being a bit vague with my issues but like I said I'm a complete newbie and learning as I go.
bandjoey
post Feb 9 2013, 07:56 PM
bandjoey
Search Hot Start. It's a common problem. Multiple threads on a simple fix. On my cell so I'm not searching for u now. Also the grounds need a good cleaning for contact. After 40 years corrosion causes bad starts. Jeff bowsley has a diagram of all the grounds. Sandpaper a file and electronic cleaner them all. A big one next to the starter is the transmission ground strap.
Do this and you'll discover lots about the electrical system. (IMG:style_emoticons/default/beerchug.gif)
Noodles   Newbie with a few questions!   Feb 9 2013, 04:55 PM
914itis   It is possible that the hesitation and backfire ar...   Feb 9 2013, 07:05 PM
rhodyguy   if money and time are issues post a wtb for the co...   Feb 9 2013, 07:14 PM
Jeffs9146   Have you tried it again since it cooled down? If i...   Feb 9 2013, 07:19 PM
bandjoey   Search Hot Start. It's a common problem. Multi...   Feb 9 2013, 07:56 PM
ThePaintedMan   May I make a small suggestion to the veteran membe...   Feb 9 2013, 08:04 PM
timothy_nd28   To me, it sounds like its running lean. I'm a...   Feb 9 2013, 09:15 PM
timothy_nd28   I just noticed that you adjusted your valves recen...   Feb 9 2013, 09:23 PM
somd914   Since it sounds like you are not completely sure w...   Feb 9 2013, 10:55 PM
Noodles   Started right up this morning so I'll clean th...   Feb 10 2013, 10:31 AM
Noodles   One more pic of air box if that helps any. http://...   Feb 10 2013, 10:35 AM
Tom   A tip that has helped many is this, prior to turni...   Feb 10 2013, 12:16 PM
Cupomeat   Well, just in case it wasn't clear, that is a ...   Feb 10 2013, 12:25 PM
Tom   Clear to me, as I stated, I know it helps on D-Jet...   Feb 10 2013, 01:16 PM
timothy_nd28   Stick with the basics before ordering a slew of po...   Feb 10 2013, 01:32 PM
rhodyguy   somebody in the greater seattle area must have a g...   Feb 10 2013, 02:06 PM
markyb   Check out the de-cel valve. I have a 1.8 with a b...   Feb 10 2013, 02:35 PM
Black22   To me, it sounds like its running lean. The air f...   Feb 10 2013, 03:22 PM
- Lo-Fi Version Time is now: 3rd July 2025 - 11:27 PM
