> Newbie with a few questions!, Car don't want to fire back up after running for awhile.
Noodles
post Feb 9 2013, 04:55 PM
Went for a drive today since I finally got a day off on a weekend that it's not raining. (IMG:style_emoticons/default/driving.gif) Had a blast for a good 45min cruising around some back roads. While driving It backfired a few times and had a slight hesitation from coming from a complete stop. It also died once or twice but it didn't have to bad an issue starting back up.
When I got back home it sat for maybe 2 min and then when I tried to move it, it didn't want to start. It was turning over just fine just didn't want to fire up.
It's a 1.8 fuel injected 75. Was told when I bought it, it was upgraded to a 2.0 but I have no proof of that. I also have a huge hole in my muffler which brings me to my next question. I took a muffler from my 72 parts car and was wondering if I can just bolt it right on to replace it.
Any help on where I should start looking for my problem would be much appreciated. I'm sure I'm being a bit vague with my issues but like I said I'm a complete newbie and learning as I go.
Cupomeat
post Feb 10 2013, 12:25 PM
missing my NY 914 in VA
Well, just in case it wasn't clear, that is a 1.8l L-Jet AFC motor as per the picture, unless it is master of disguise.
A couple of suggestions;
1. Completely agree you have some vacuum leak, the hard hot starting, popping/back firing and the idle problem suggest that. L-Jet are fussy with vacuum leaks, and the Air flow control box must sense air moving through the flapper to make the pump run.
2. Your fuel pump should have a ball check valve that holds residual pressure in the line, thus decreasing the time it takes to get your pressure up onec the car is shut off. Check your high pressure side of the fuel curcuit after the car has been shut off to see if it has maintained pressure. Do this with a gauge, NOT be opening the lines on a hot engine. 914 engines like to burn and we don't want to lose another one.
I hope this helps.
Noodles   Newbie with a few questions!   Feb 9 2013, 04:55 PM
914itis   It is possible that the hesitation and backfire ar...   Feb 9 2013, 07:05 PM
rhodyguy   if money and time are issues post a wtb for the co...   Feb 9 2013, 07:14 PM
Jeffs9146   Have you tried it again since it cooled down? If i...   Feb 9 2013, 07:19 PM
bandjoey   Search Hot Start. It's a common problem. Multi...   Feb 9 2013, 07:56 PM
ThePaintedMan   May I make a small suggestion to the veteran membe...   Feb 9 2013, 08:04 PM
timothy_nd28   To me, it sounds like its running lean. I'm a...   Feb 9 2013, 09:15 PM
timothy_nd28   I just noticed that you adjusted your valves recen...   Feb 9 2013, 09:23 PM
somd914   Since it sounds like you are not completely sure w...   Feb 9 2013, 10:55 PM
Noodles   Started right up this morning so I'll clean th...   Feb 10 2013, 10:31 AM
Noodles   One more pic of air box if that helps any. http://...   Feb 10 2013, 10:35 AM
Tom   A tip that has helped many is this, prior to turni...   Feb 10 2013, 12:16 PM
Cupomeat   Well, just in case it wasn't clear, that is a ...   Feb 10 2013, 12:25 PM
Tom   Clear to me, as I stated, I know it helps on D-Jet...   Feb 10 2013, 01:16 PM
timothy_nd28   Stick with the basics before ordering a slew of po...   Feb 10 2013, 01:32 PM
rhodyguy   somebody in the greater seattle area must have a g...   Feb 10 2013, 02:06 PM
markyb   Check out the de-cel valve. I have a 1.8 with a b...   Feb 10 2013, 02:35 PM
Black22   To me, it sounds like its running lean. The air f...   Feb 10 2013, 03:22 PM
- Lo-Fi Version Time is now: 3rd July 2025 - 11:34 PM
