| rickwenner@acninc.net |
Feb 10 2013, 07:17 PM
Go Kart racer ![]() Group: Members Posts: 3 Joined: 18-March 12 From: BRENTWOOD, CA Member No.: 14,277 Region Association: Northern California |
Tried to go for a drive today. Pulling the car out of the garage it backfired a once and had a slight hesitation. Then as I started to pull out it also died. It started back up and a I pulled out, then a very strong hesitation, bucking forward and it died. It would starting back up, but not stay running. It was turning over just fine, but just didn't want to fire up. It's a 1.8 fuel injected 75. Any help on where I should start looking for my problem would be much appreciated. I'm sure I'm being a bit vague with my issues but like I said I'm a complete newbie and learning as I go. Attached image(s)
| timothy_nd28 |
Feb 11 2013, 02:52 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,299 Joined: 25-September 07 From: IN Member No.: 8,154 Region Association: Upper MidWest
I think you're on the right track. Replace the regulator and since you are in there, replace the fuel lines in the engine bay and fuel tank area with some ethanol rated fuel injector hose. Do you still have the original plastic fuel lines running thru the tunnel? Also, if you have time, remove the top plastic fuel reservoir on top of the gas tank, and inspect the condition of your fuel, fuel sock and rust inside your tank. There should be just enough room to shine a flash light inside your tank, after the plastic reservoir is removed.
rickwenner@acninc.net Newbie needs help! Feb 10 2013, 07:17 PM
timothy_nd28 After starting the car, will it idle indefinitely ... Feb 10 2013, 07:43 PM
After starting the car, will it idle indefinitely... Feb 11 2013, 01:24 PM
L73 Yep, this reminds me of me 6 years ago with my L-j... Feb 10 2013, 07:56 PM
rick 918-S :wttc: Check the fuel pump relay. Feb 10 2013, 09:58 PM
jdlmodelt Make sure one of your injector wires didn't co... Feb 11 2013, 07:38 AM
jdlmodelt
I think you're on the right track. Replace t... Feb 11 2013, 09:38 PM
type47 Have you ever disconnected the fuel lines, like wh... Feb 11 2013, 06:25 PM![]() ![]() |
Lo-Fi Version | Time is now: 14th September 2026 - 07:01 AM |
