Carb Choice, Weber 34 VS 40 |
Mblizzard |
Feb 14 2013, 12:24 PM
Advanced Member Group: Members Posts: 3,033 Joined: 28-January 13 From: Knoxville Tn Member No.: 15,438 Region Association: South East States |
I have been sorting through some questionable past mechanical choices that were implemented on my 1.9 (1.8 with 96mm cylinders). Currently it seems to have some type of single Weber a 32 I think that seems to have come off a Ford car. Not a good choice of carbs by any measure. Of course will be going back with dual Webers but I am struggling between the 34 and 40. The 40s are much more attractive than the 34s but there is a sizable cost difference. The 34s are about $400 and the 40s $600. I plan on driving the car on the road and I am just looking for something that has the ability to be drivable but also deliver the performance when called upon. Other than appearance, is there any reason to go to the 40s? It seems that the 34s would be sufficient. Thoughts?
Mblizzard |
Feb 15 2013, 12:28 PM
OK it looks like 40s it is! The best cost I have found is at Weber Carbs Direct. Are there any other sources to buy the kit?
Thanks for the.comments they helped a lot. Just to show what some view as a repair, check out the connection of the throttle cable to the carb. Yes that is what appears to be the pull chain from a light switch! Attached image(s) |
Lo-Fi Version | Time is now: 10th June 2024 - 03:40 AM |
