Carb Choice, Weber 34 VS 40 |
Mblizzard |
Feb 14 2013, 12:24 PM
Advanced Member Group: Members Posts: 3,033 Joined: 28-January 13 From: Knoxville Tn Member No.: 15,438 Region Association: South East States |
I have been sorting through some questionable past mechanical choices that were implemented on my 1.9 (1.8 with 96mm cylinders). Currently it seems to have some type of single Weber a 32 I think that seems to have come off a Ford car. Not a good choice of carbs by any measure. Of course will be going back with dual Webers but I am struggling between the 34 and 40. The 40s are much more attractive than the 34s but there is a sizable cost difference. The 34s are about $400 and the 40s $600. I plan on driving the car on the road and I am just looking for something that has the ability to be drivable but also deliver the performance when called upon. Other than appearance, is there any reason to go to the 40s? It seems that the 34s would be sufficient. Thoughts?
rhodyguy |
Feb 15 2013, 02:04 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,093 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
all i saw were 44s (unless i looked in the wrong place). if that's all they have and the IDFs have 36mm venturis be prepared to change things with your 1911cc displacement.
do they come with the velosity stacks as pictured? if you're buying just the carbs don't forget to buy a linkage kit and a filter set. some kits may not come with a throttle cable holder. call them and ? to ask. 1. where are the carbs manufactured? 2. what is the warranty? 3. do your linkages come with a throttle cable holder? buy the CB weber book. have fun. k |
Mblizzard |
Feb 15 2013, 02:17 PM
all i saw were 44s (unless i looked in the wrong place). if that's all they have and the IDFs have 36mm venturis be prepared to change things with your 1911cc displacement. do they come with the velosity stacks as pictured? if you're buying just the carbs don't forget to buy a linkage kit and a filter set. some kits may not come with a throttle cable holder. call them and ? to ask. 1. where are the carbs manufactured? 2. what is the warranty? 3. do your linkages come with a throttle cable holder? buy the CB weber book. have fun. k You have to search for the 40s. If you do you get http://www.webercarbsdirect.com/product_p/wk288.htm. It seems to be the whole package. |
Lo-Fi Version | Time is now: 10th June 2024 - 07:34 AM |
