911 hubs on 914 Struts? |
Kevins911 |
Feb 18 2013, 04:05 PM
Member Group: Members Posts: 52 Joined: 15-July 05 From: Kelowna, B.C. Member No.: 4,420 Region Association: Canada |
Trying to go 5 lug on a budget, I had these 911 front hubs on the shelf and was curious if they would work. They seem to fit fine, the bearings all sit where they need to, the only issue I can see is the inner bearing seal not fitting the spindle, no problem really, just get a custom seal from the local auto parts store.
The car is a '73. Does anyone see a problem with this? Thanks Kevin |
Kevins911 |
Feb 18 2013, 04:35 PM
Some early 911's/912's used solid rotors, but I plan on using vented rotors with either M calipers or these 4 piston calipers. I expect to have to machine some material of the caliper mounting ears either way as I think the mounting offset changed in '73.
Lo-Fi Version | Time is now: 9th June 2024 - 06:15 PM |
