> lowering my 914, some wheel work
johnpierre
post Feb 18 2013, 12:32 PM
hey everyone (at least here in los angeles). i want to lower my 73 a little, or at least explore the idea. i want it done as best as possible, i.e. ride quality, steering geometry etc. does anyone know of someone or a shop (here locally) that i can trust and that has plenty of experience doing this on 914s. i also want to strip the paint on my rivieras, and repaint them, i suppose that would just be any paint shop right ?
Tom_T
post Feb 18 2013, 02:47 PM
TMI....
Otto's in Venice knows 914s well for the suspension & any other mechanical work.
You could refinish the Rivieras yourself - strip & repaint, smooth out minor curb-rash, if they're not too bad. Look up some of the wheel refinishing threads on here & adapt to Rivieras.
r_towle
post Feb 18 2013, 05:07 PM
Custom Member
QUOTE(Tom_T @ Feb 18 2013, 03:47 PM) *
I believe Otto recently passed away.
There is a thread here on that.
Lowering the car will create compromises that you need to understand.
To low, and the car becomes stiff, hits potholes and shakes teeth.
To low and you end up with twitchy steering sometimes called "bump steering"
We have all scraped the ground and all raised them back up again.
Never let the front a-arm get beyond level, that is to low and requires modifications to get it to be right...
You will need to get an alignment after you lower the car.
You will need to buy adjustable perch rear shocks to give you any adjustment in the rear.
Front is simple, turn the adjusters to lower it.
rich
johnpierre
post Feb 18 2013, 06:05 PM
QUOTE(r_towle @ Feb 18 2013, 03:07 PM) *
rich
that is good insight. as it turns out, it is the front that i want to lower more, to create a slight racked look. when you say, the front is easier and just turn adjusters is that something i can do without taking everything apart?
r_towle
post Feb 18 2013, 06:34 PM
Custom Member
QUOTE(johnpierre @ Feb 18 2013, 07:05 PM) *
rich
Simple to do, see pic above.
Measure at the bottom of the rocker panel, both front and rear.
I shoot for about 1/4 inch lower in front than in the rear when measured at the rocker panel.
Measuring the fender lip is filled with to many variations....
I also use a block of wood put right under the adjuster, measured to the exact height I want on one side...then go to the other side and slide the block in place....lower car to block...
Its faster than trying to hold a tape measure while adjusting the bolt...while trying to read the tape measure....etc...
If you want it perfect, sit in the front seat and have someone do it again with the weight on one side..
Then the car rides perfect with you in it, but looks odd when you are not in it.
rich
johnpierre   lowering my 914, some wheel work   Feb 18 2013, 12:32 PM
L73   hey everyone (at least here in los angeles). i wa...   Feb 18 2013, 12:45 PM
johnpierre   hey everyone (at least here in los angeles). i w...   Feb 18 2013, 12:48 PM
johnpierre   by the way does anyone have any opinions on loweri...   Feb 18 2013, 12:52 PM
KaptKaos   If you're in Venice, check in with Alex at Pre...   Feb 18 2013, 01:26 PM
johnpierre   If you're in Venice, check in with Alex at Pr...   Feb 18 2013, 01:49 PM
Tom_T   Otto's in Venice knows 914s well for the suspe...   Feb 18 2013, 02:47 PM
r_towle   Otto's in Venice knows 914s well for the susp...   Feb 18 2013, 05:07 PM
johnpierre   Otto's in Venice knows 914s well for the sus...   Feb 18 2013, 06:05 PM
johnpierre   [quote name='r_towle' post='1822384' date='Feb 18...   Feb 18 2013, 06:06 PM
r_towle   [quote name='r_towle' post='1822384' date='Feb 18...   Feb 18 2013, 06:34 PM
worn   You will need to buy adjustable perch rear shoc...   Feb 19 2013, 01:02 PM
KaptKaos   Otto's in Venice knows 914s well for the susp...   Feb 18 2013, 05:08 PM
johnpierre   Otto's in Venice knows 914s well for the susp...   Feb 19 2013, 01:31 AM
messix   yes if you look at rear part of the front suspensi...   Feb 18 2013, 06:25 PM
johnpierre   man, you guys are the shit. i love this website, t...   Feb 18 2013, 06:58 PM
euro911   Hey JP, you only need an 11mm wrench to lower the ...   Feb 19 2013, 02:30 AM
johnpierre   Hey JP, you only need an 11mm wrench to lower the...   Feb 19 2013, 12:34 PM
johnpierre   Hey JP, you only need an 11mm wrench to lower th...   Feb 28 2013, 06:49 PM
KaptKaos   Gotta love them 'Moons' :lol: :barf...   Feb 19 2013, 12:42 PM
Cupomeat   You are generally constrained to buying a rear sho...   Feb 19 2013, 01:08 PM
Randal   You are generally constrained to buying a rear sh...   Feb 19 2013, 01:18 PM
Cupomeat   Also, I know it was said, but you will need to adj...   Feb 19 2013, 01:51 PM
falconfp2001   You can buy some Bump Steer spacers also. This wil...   Feb 21 2013, 09:00 PM
johnpierre   You can buy some Bump Steer spacers also. This wi...   Feb 21 2013, 09:08 PM
euro911   Here's the tech article on 'How to install...   Feb 21 2013, 10:17 PM
johnpierre   Here's the tech article on 'How to instal...   Feb 22 2013, 03:01 AM
johnpierre   Here's the tech article on 'How to instal...   Feb 26 2013, 05:29 PM
jdlmodelt   I'm hoping changing the tires will level her o...   Feb 26 2013, 08:36 PM
jmill   If you remove the adjuster bolt you can pop the ca...   Feb 26 2013, 10:06 PM
jdlmodelt   If you remove the adjuster bolt you can pop the c...   Feb 27 2013, 04:19 PM
- Lo-Fi Version Time is now: 7th July 2025 - 08:25 AM
