mepstein |
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,970 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region ![]() ![]() |
When I first got the car last year, all lights worked. Now, none of the white lights on the dash work but the colored lights for the turn signals, headlight indicators and gas gauge are working. Backpad light doesn't work either. Any ideas of where to look? thanks!
mepstein |
Forgot to say that only my low beams work. High beams are dark. Also the fans in the engine compartment and front cowl don't work. All the other exterior lights work. Related?
PS - I'm not an electrical guy so go easy on me with suggested testing. |
rgalla9146 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,781 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None ![]() ![]() |
Forgot to say that only my low beams work. High beams are dark. Also the fans in the engine compartment and front cowl don't work. All the other exterior lights work. Related? PS - I'm not an electrical guy so go easy on me with suggested testing. Verify 12V at the light. Then go after the corroded door switches ( use a safety razor to scrape the pointy contacts and don't let the wires fall into the hinge post ! ) The lamp switch has three positions. Off. On. And switched by either door. Verify that the correct bulb is in place !.....or risk melting your light and roasting the surrounding upholstery. |
Lo-Fi Version | Time is now: 15th July 2025 - 11:03 AM |
