mepstein |
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,970 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region ![]() ![]() |
When I first got the car last year, all lights worked. Now, none of the white lights on the dash work but the colored lights for the turn signals, headlight indicators and gas gauge are working. Backpad light doesn't work either. Any ideas of where to look? thanks!
hot_shoe914 |
on ramp passer ![]() ![]() ![]() ![]() Group: Members Posts: 3,807 Joined: 20-November 07 From: Earle, Ar. Member No.: 8,354 Region Association: None ![]() |
Try turning the knob to see if the dash lights come on. (IMG:style_emoticons/default/poke.gif)
mepstein |
Really? Yes, I tried that. All this stuff worked when I bought the car a year ago so I'm thinking it must be some connections, not corrosion. |
hot_shoe914 |
Really? Yes, I tried that. All this stuff worked when I bought the car a year ago so I'm thinking it must be some connections, not corrosion. I assume you have checked all the fuses? (IMG:style_emoticons/default/confused24.gif) |
mepstein |
Really? Yes, I tried that. All this stuff worked when I bought the car a year ago so I'm thinking it must be some connections, not corrosion. I assume you have checked all the fuses? (IMG:style_emoticons/default/confused24.gif) Yes |
scotty b |
rust free you say ? ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 16,375 Joined: 7-January 05 From: richmond, Va. Member No.: 3,419 Region Association: None ![]() |
Really? Yes, I tried that. All this stuff worked when I bought the car a year ago so I'm thinking it must be some connections, not corrosion. I assume you have checked all the fuses? (IMG:style_emoticons/default/confused24.gif) Yes You have alot of things that are unrelated going on. Have you checked the fuse ends, and fuse block tangs for corrosion ? |
Lo-Fi Version | Time is now: 15th July 2025 - 10:43 AM |
