Jboulder |
Newbie ![]() Group: Members Posts: 2 Joined: 4-June 11 From: Tempe, AZ Member No.: 13,154 Region Association: Rocky Mountains ![]() |
My 912E is running a 2L with dual weber 40 IDF's. Right now it's got some 009 with electronic ignition.
Would a currently available (i.e. not bosch) SVDA distributor be an upgrade? I'm looking for a reasonable mix of performance and fuel economy. Thanks in advance! (pun intended) |
KaptKaos |
Family ![]() ![]() ![]() ![]() Group: Members Posts: 4,009 Joined: 23-April 03 From: Near Wausau Member No.: 607 Region Association: Upper MidWest ![]() |
I like mine. Good power and economy, but I think I need more advance at idle. Throttle response is a little sluggish. Once past tip in, it screams!
Do your webers have a vacuum port? You will need one. |
mrbubblehead |
Twodollardoug ![]() ![]() ![]() Group: Members Posts: 1,155 Joined: 17-December 10 From: calimesa ca. Member No.: 12,492 Region Association: Southern California ![]() |
I like mine. Good power and economy, but I think I need more advance at idle. Throttle response is a little sluggish. Once past tip in, it screams! Do your webers have a vacuum port? You will need one. ive got my total advance cranked up to 35 degrees max advanced now. svda distributor, and my cyl. head temps went DOWN 25 degrees. AT LEAST 25. |
KaptKaos |
I like mine. Good power and economy, but I think I need more advance at idle. Throttle response is a little sluggish. Once past tip in, it screams! Do your webers have a vacuum port? You will need one. ive got my total advance cranked up to 35 degrees max advanced now. svda distributor, and my cyl. head temps went DOWN 25 degrees. AT LEAST 25. I'd have to go through all of the mixture adjustments if I advance it, no? |
mrbubblehead |
Lo-Fi Version | Time is now: 11th June 2024 - 04:05 AM |
