| billh1963 |
Feb 20 2013, 06:44 AM
Car Hoarder! ![]() ![]() ![]() ![]() Group: Members Posts: 3,431 Joined: 28-March 11 From: North Carolina Member No.: 12,871 Region Association: South East States |
1970 through 1972.8 - Early 914 Package P/N 914.351.352.01
Retail = $720.40 Discount = $144.08 Group Buy Total = $576.32 Commitments: 1. Gene 2. Eyesright 3. Igo914 1972.8 through 1976 - Late 914 Package P/N 914.351.352.02 (Centering Ring will be machined off the front rotors) Retail = $772.40 Discount = $154.48 Group Buy Total = $617.92 Commitments: 1. billh1963 2. billh1963 3. Chris H. 4. Philip W. 5. Darin300 6. Nie Zu Alt 7. KENNY 8. MrLeeS This Group Buy will need to have 10 or more participants to get the pricing where we need it. The price includes the following items: (2) Front Rotors (early or late) machined to 5x130 with studs included. (2) Sets of bearings and seals for above. (2) Rear rotors machined to 5x130. (2) Machined Hubs (you must supply the cores) freshly plated in silver zinc with studs included. (2) Rear wheel bearings. To be a part of this group buy you must send in a pair of rear hubs. The machining costs are based upon a minimum of 10 pair of rear hubs and ten pair of front rotors. ***IMPORTANT*** Once the group buy reaches the minimum on the hubs and rotors we can talk about pricing on separate units ('hey... how much for a pair of rear hubs only?" -or- "how much for an extra pair of front rotors?") GROUP BUY ENDS 3/3/2013 (we will extend it through the All Porsche Swap Meet and Car Show in Anaheim) So.... going 5-lug for $6-clams with all new components and new bearings ta boot?!?!? Yeah... it's a good deal. If you look at the rotor pricing alone, this is just $22 - $24 more per rotor over the stock pricing but it includes the machining and studs! On the rear hubs the savings is around $30.00... Again, this is a complete soup to nuts 914 5-lug package. Bearings, seals rotors, hubs and studs. It's all there ready for you to bolt it on. These will be screw in studs with Red Loctite as seen below. Picture of a late model front rotor with the centering ring machined off and the 5x130 pattern machined into the hub section (IMG:http://www.914world.com/bbs2/uploads/post-1110-1284690383_thumb.jpg) It shouldn't be too hard to find 10 people in this big ole world of ours who want this at the best price possible. Commit now and be cruising in style this summer... |
| Eric_Shea |
Feb 26 2013, 07:06 PM
PMB Performance ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 19,304 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
I'm purchasing 10 pair of cores for the rear hubs to not only get this started faster but to facility future orders. We should OK but there will be a core charge if you want to do the swap.
I also put myself down for one each of the kits for shelf stock (which I'll sell later at a higher price if people don't come in on the buy) (IMG:style_emoticons/default/tongue.gif) Also looking to open this up for: 1. Rear Hub Purchases - $116 per pair plus your cores. These are zinc plated, drilled for 5x130 and studded. 2. Rear Rotor Purchases - $83.60 each. Zimmer 914-4 rear rotors drilled to the 5x130 pattern. Advantages: cheaper than trimming the edge off a 914-6 rotor. Mounting screws will work with modified 914-4 rear hubs. 3. Early 5-lug Front Rotor Purchases - $89.60 each drilled and with studs. 4. Late 5-lug Front Rotor Purchases - $110.40 each drilled and with studs. The cheap elite will be getting out their calculators and realizing these are less than the buy but... don't forget the bearings because you'll need them and, they'll be more expensive than they are here. You'll be doing one of these (IMG:style_emoticons/default/headbang.gif) when you find out you have to pay more later! (IMG:style_emoticons/default/biggrin.gif) |
billh1963 GROUP BUY: 5-LUG CONVERSION - Drilled 914 front rotors and rear hubs Feb 20 2013, 06:44 AM
billh1963 I am definitely in for one...maybe two pending fin... Feb 20 2013, 06:46 AM
76-914 :popcorn: Feb 20 2013, 08:42 AM
biosurfer1 Pending prices, I would be interested too. Feb 20 2013, 09:14 AM
r_towle Pending prices , I would be up for it.
I would pre... Feb 20 2013, 10:11 AM
billh1963
I would pr... Feb 20 2013, 12:11 PM
Eric_Shea I'll use this post to explain some of the bene... Feb 20 2013, 02:13 PM
billh1963 I'm in for two late packages! IIRC in one ... Feb 20 2013, 02:18 PM
Eric_Shea
No stone unturned Weedhopper. :hopper: Feb 20 2013, 02:30 PM
billh1963
Duh... Feb 20 2013, 02:35 PM
Vacca Rabite Hershey delivery? Feb 20 2013, 05:26 PM
Chris H. I'm in for one late set....nice deal.
Eric,... Feb 20 2013, 06:14 PM
Eric_Shea Porterfield R4S pads are our all time favorite for... Feb 20 2013, 06:34 PM
Chris H. OK cool. Thanks. Upcharge for longer studs is fi... Feb 20 2013, 06:41 PM
Philip W. Add me to the list for one set of late for my... Feb 20 2013, 06:45 PM
billh1963 Anyone else? Feb 21 2013, 05:39 PM
Darin300 I would be in for late set also.. Feb 21 2013, 06:40 PM
Eric_Shea Thanks Darin... Sure beats the other price you saw... Feb 21 2013, 08:21 PM
balljoint :bump: Feb 22 2013, 01:32 PM
adiokyro being difficult: I need the rear 5 lug hubs/discs ... Feb 22 2013, 05:29 PM
billh1963 :bump: Feb 23 2013, 06:28 PM
billh1963 :bump: Feb 26 2013, 05:50 AM
Eric_Shea Last week to save $$$.$$ ... Feb 26 2013, 08:20 AM
eyesright I have a '70 nightmare -6 conversion that I bo... Feb 26 2013, 08:52 AM
Chris H. Check the classifieds...lots of 4 lug hub chatter.... Feb 26 2013, 09:59 AM
billh1963
Check the classifieds...lots of 4 lug hub chatter... Feb 26 2013, 10:40 AM
KENNY Add me to the list for one late set.if this go tru... Feb 26 2013, 03:10 PM
Chris H. KENNY you mighty be #10!!!!!... Feb 26 2013, 03:15 PM
KENNY
KENNY you mighty be #10!!!!!... Feb 26 2013, 06:45 PM
Philip W. :bump:
so that means we are on for sure? :beer... Feb 27 2013, 01:48 PM
FL 000 Special request on the a la carte menu - I have 2 ... Feb 27 2013, 10:01 PM
Eric_Shea
Special request on the a la carte menu - I have 2... Feb 28 2013, 12:10 AM
Nie Zu Alt Eric,
Put me down for a late set for my '74. ... Feb 28 2013, 12:17 AM
igo914 Eric,
If its not too late, put me down for a earl... Mar 2 2013, 09:28 AM
billh1963 GB ends today.... Mar 3 2013, 05:58 AM
Nie Zu Alt So, what's the next step with this process? Er... Mar 8 2013, 10:16 AM
Eric_Shea Yes. Need hubs ASAP. I'm cataloging the GB r... Mar 8 2013, 10:53 AM
Nie Zu Alt Thanks Eric. I'll get the hubs in the mail to ... Mar 8 2013, 11:34 AM
Eric_Shea OK Gang...
Everybody should have an estimate e-ma... Mar 8 2013, 06:37 PM
billh1963 Thank you, Eric! Paypalling Monday morning. Wi... Mar 8 2013, 07:32 PM
Chris H. This is getting REAL now!!! I'll ... Mar 8 2013, 08:00 PM
billh1963 Paid for two sets.....hubs shipping today. Looking... Mar 11 2013, 07:39 AM
rpmmaxxed Did the deadline stick? Mar 11 2013, 09:49 AM
Eric_Shea
Meaning?
Yes, we'r... Mar 11 2013, 09:51 AM
dpires914 PM sent Apr 8 2013, 10:51 AM
Eric_Shea ***UPDATE***
Trying to wrap this up before the en... Mar 29 2013, 10:18 AM
billh1963 Exciting to see some progress! Looking forward... Mar 29 2013, 10:22 AM
bulitt Eric- now that you have all these fixtures and jig... Mar 29 2013, 12:40 PM
Eric_Shea
Should be as follows:
$25.00 per rotor for... Mar 29 2013, 01:56 PM
balljoint Is this in house or out sourced? Mar 29 2013, 03:41 PM
sixnotfour That's drilled and tapped ...correct ?? Mar 29 2013, 06:24 PM
Eric_Shea Just keeping everyone up to speed. All of the par... Apr 4 2013, 04:11 PM
Chris H. Here's a special order with the 80mm studs:
ht... Apr 4 2013, 05:13 PM
SKL1 Email sent- need rear rotors that will fit OEM ... Apr 4 2013, 09:20 PM
bcheney Just saw this Thread...Eric you are the best! ... Apr 5 2013, 05:09 AM
balljoint Eric,
Can this be special ordered in four lug? Apr 5 2013, 05:10 AM
MDG
Eric,
... Apr 9 2013, 04:50 PM
bulitt Awesome Eric! Possibly in your spare time you... Apr 5 2013, 05:18 AM
billh1963 I hope those boxes hold up! I have not been im... Apr 8 2013, 12:52 PM
Philip W.
I hope those boxes hold up! I have not been i... Apr 8 2013, 01:16 PM
Eric_Shea Double boxed with extra tape.
5-Lug guys... now... Apr 8 2013, 07:13 PM
r_towle eric,
forgot all about this one.
Please bring som... Apr 8 2013, 08:12 PM
Eric_Shea Early or late? Apr 9 2013, 07:01 AM
Eric_Shea Toad lickers... <_< Apr 9 2013, 05:55 PM
balljoint
Toad lickers... <_<
:confused:
Well, if ... Apr 10 2013, 07:28 PM
r_towle Late style.
Gotta love it....Wifi on a plane is j... Apr 9 2013, 07:40 PM
Chris H. Well, well, look what the cat dragged in.
All t... Apr 10 2013, 10:44 AM
Eric_Shea :trophy: Apr 10 2013, 11:27 AM
KENNY Just got my 5 lug conversion .Thanks Eric! :d... Apr 10 2013, 03:06 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 09:33 PM |
