Turn Signal Electrical Puzzle, 911 Tach |
Eric_Shea |
Feb 21 2013, 10:21 PM
PMB Performance Group: Admin Posts: 19,278 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
Gang,
Looking for any BTDT advice or electrical guru input. I have everything on the dash working and wired in. The only puzzle is the turn signal indicators in the tach. When the stalk is engaged the gauge indicator light illuminates (and clicks) "once" and then stops. The external turn signals all work properly. Any thoughts on why the gauge lights would only flash once and then stop? Thanks! |
Tom_T |
Feb 22 2013, 02:44 PM
TMI.... Group: Members Posts: 8,318 Joined: 19-March 09 From: Orange, CA Member No.: 10,181 Region Association: Southern California |
Eric & jdmodelt both need to look at the flasher/TS relay, as that was usually the culprit on mine - and when they get weak or iffy, then the headlights will tax them into not working in conjunction.
Also jd' - if you added higher power headlights without the relay for them, that could cause your problem. |
jdlmodelt |
Feb 26 2013, 09:08 PM
James D. Lane Group: Members Posts: 345 Joined: 30-November 12 From: Colorado Member No.: 15,210 Region Association: Southwest Region |
Eric & jdmodelt both need to look at the flasher/TS relay, as that was usually the culprit on mine - and when they get weak or iffy, then the headlights will tax them into not working in conjunction. Also jd' - if you added higher power headlights without the relay for them, that could cause your problem. I added newer, brighter lights. j |
Lo-Fi Version | Time is now: 8th June 2024 - 07:23 AM |
