> lowering my 914, some wheel work
johnpierre
post Feb 18 2013, 12:32 PM
hey everyone (at least here in los angeles). i want to lower my 73 a little, or at least explore the idea. i want it done as best as possible, i.e. ride quality, steering geometry etc. does anyone know of someone or a shop (here locally) that i can trust and that has plenty of experience doing this on 914s. i also want to strip the paint on my rivieras, and repaint them, i suppose that would just be any paint shop right ?
jmill
post Feb 26 2013, 10:06 PM
Green Hornet
If you remove the adjuster bolt you can pop the cap off the torsion bar. Re-index the cap on the bar to give you more adjustment. Cap might be froze on the bar. When you try and pop off the cap the bar comes out with it. No biggie. Re index the bar. Do this when it's up on jackstands. Dont want the car falling on you.
johnpierre   lowering my 914, some wheel work   Feb 18 2013, 12:32 PM
L73   hey everyone (at least here in los angeles). i wa...   Feb 18 2013, 12:45 PM
johnpierre   hey everyone (at least here in los angeles). i w...   Feb 18 2013, 12:48 PM
johnpierre   by the way does anyone have any opinions on loweri...   Feb 18 2013, 12:52 PM
KaptKaos   If you're in Venice, check in with Alex at Pre...   Feb 18 2013, 01:26 PM
johnpierre   If you're in Venice, check in with Alex at Pr...   Feb 18 2013, 01:49 PM
Tom_T   Otto's in Venice knows 914s well for the suspe...   Feb 18 2013, 02:47 PM
r_towle   Otto's in Venice knows 914s well for the susp...   Feb 18 2013, 05:07 PM
johnpierre   Otto's in Venice knows 914s well for the sus...   Feb 18 2013, 06:05 PM
johnpierre   [quote name='r_towle' post='1822384' date='Feb 18...   Feb 18 2013, 06:06 PM
r_towle   [quote name='r_towle' post='1822384' date='Feb 18...   Feb 18 2013, 06:34 PM
worn   You will need to buy adjustable perch rear shoc...   Feb 19 2013, 01:02 PM
KaptKaos   Otto's in Venice knows 914s well for the susp...   Feb 18 2013, 05:08 PM
johnpierre   Otto's in Venice knows 914s well for the susp...   Feb 19 2013, 01:31 AM
messix   yes if you look at rear part of the front suspensi...   Feb 18 2013, 06:25 PM
johnpierre   man, you guys are the shit. i love this website, t...   Feb 18 2013, 06:58 PM
euro911   Hey JP, you only need an 11mm wrench to lower the ...   Feb 19 2013, 02:30 AM
johnpierre   Hey JP, you only need an 11mm wrench to lower the...   Feb 19 2013, 12:34 PM
johnpierre   Hey JP, you only need an 11mm wrench to lower th...   Feb 28 2013, 06:49 PM
KaptKaos   Gotta love them 'Moons' :lol: :barf...   Feb 19 2013, 12:42 PM
Cupomeat   You are generally constrained to buying a rear sho...   Feb 19 2013, 01:08 PM
Randal   You are generally constrained to buying a rear sh...   Feb 19 2013, 01:18 PM
Cupomeat   Also, I know it was said, but you will need to adj...   Feb 19 2013, 01:51 PM
falconfp2001   You can buy some Bump Steer spacers also. This wil...   Feb 21 2013, 09:00 PM
johnpierre   You can buy some Bump Steer spacers also. This wi...   Feb 21 2013, 09:08 PM
euro911   Here's the tech article on 'How to install...   Feb 21 2013, 10:17 PM
johnpierre   Here's the tech article on 'How to instal...   Feb 22 2013, 03:01 AM
johnpierre   Here's the tech article on 'How to instal...   Feb 26 2013, 05:29 PM
jdlmodelt   I'm hoping changing the tires will level her o...   Feb 26 2013, 08:36 PM
jmill   If you remove the adjuster bolt you can pop the ca...   Feb 26 2013, 10:06 PM
jdlmodelt   If you remove the adjuster bolt you can pop the c...   Feb 27 2013, 04:19 PM
- Lo-Fi Version Time is now: 7th July 2025 - 07:53 AM
