jmargush |
Member ![]() ![]() Group: Members Posts: 484 Joined: 8-June 04 From: Goshen, IN Member No.: 2,176 ![]() |
I had a slight issues while assembling one of the rods to my crank.
As I got the nuts snugged up the rod was tight and didn't really rotate. Pulled it back apart and looks like the bearing must have slipped or rotated, and the tang on the bearing crushed and actually marred up the slot on the connecting rod too. Bearing looks like it is toast Can you buy just 2 halves of a rod bearing or do you have to buy a whole other set? Hopefully cleaning up the rod won't mess up the balance job too bad. |
Mike Bellis |
Resident Electrician ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,347 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None ![]() ![]() ![]() |
I think you have to buy a whole set unless you can exactly identify it (by size and part number) and deal with a manufacturer.
Most people do not have spares... (IMG:style_emoticons/default/sad.gif) |
Lo-Fi Version | Time is now: 11th July 2025 - 01:51 PM |
