jmargush |
Member ![]() ![]() Group: Members Posts: 484 Joined: 8-June 04 From: Goshen, IN Member No.: 2,176 ![]() |
I had a slight issues while assembling one of the rods to my crank.
As I got the nuts snugged up the rod was tight and didn't really rotate. Pulled it back apart and looks like the bearing must have slipped or rotated, and the tang on the bearing crushed and actually marred up the slot on the connecting rod too. Bearing looks like it is toast Can you buy just 2 halves of a rod bearing or do you have to buy a whole other set? Hopefully cleaning up the rod won't mess up the balance job too bad. |
Valy |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,677 Joined: 6-April 10 From: Sunnyvale, CA Member No.: 11,573 Region Association: Northern California ![]() |
Post an add in the classifieds. Maybe someone went through the same thing.
I don't thing the rod got damaged since the bearings are soft and will give first. |
Lo-Fi Version | Time is now: 11th July 2025 - 03:43 PM |
