Factory Front Stablizer Support Bracket, 914.501.162.10 |
914Sixer |
Feb 16 2013, 05:30 PM
914 Guru Group: Members Posts: 8,903 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Just wanted to let everybody know these are still available from Porsche. Drill your holes, position and weld.
Attached image(s) |
ChrisFoley |
Mar 2 2013, 05:55 AM
I am Tangerine Racing Group: Members Posts: 7,934 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
Welding the oem reinforcements on the outside is fine for a factory bar on a street car with relatively narrow tires.
For competition cars and modified street cars a heavier duty plate should be welded on the inside so the inner fender is sandwiched between the reinforcement and the support bracket. The reinforcements I've been making for many years have the same tri-oval shape as oem but the nuts are more securely welded to a heavier gauge plate. They should be 100% perimeter welded or stress cracks will eventually propagate from the ends of the welds. I've raced for years using a 1 1/4" anti-sway bar without any cracks occurring in the chassis, My bar has more than twice the stiffness of a 22mm solid bar. I've seen the factory reinforcements torn out of cars with less anti-sway bar and less tire than my car. |
Lo-Fi Version | Time is now: 8th June 2024 - 10:44 PM |
