> Side Shift Adjustment, Search and have Dr Evils NOTES But shifting still is crap
Mblizzard
post Mar 3 2013, 06:00 PM
OK! I searched the board, got Dr Evils notes. Replaced every bushing. Even the firewall bushing and lubed everything well. Studied everything for broken mounts or transmission ears. Read Zen and the Art of Motorcycle Maintenance. Made multiple attempts to adjust and it shifts like crap. I must really suck at this!
I can get first and reverse but every thing is still a mystery. It seems like going from first to second always winds up in 4th. Yes I did the 3rd 2nd alignment sequester by Dr Evil multiple times with the same results. So I must be doing something wrong. (IMG:style_emoticons/default/headbang.gif)
Or the shifter is bad. Looking at the shifter it is worn and certainly will require replacement at some point but it seems to be functioning as intended.
I guess in the adjustment process I did verify the gears at the transmission but I am confused as how to "adjust to where a gear should be." Also the directions say to secure the shift rod in the tunnel while you tighten the pinch nut. But with the new bushings there is some resistance to movement. Not binding any where just new.
So what am I missing? Should I drink while making the adjustments? (IMG:style_emoticons/default/beer3.gif)
Kaduku
post Mar 4 2013, 01:43 PM
Mine grinds when I shift too soon into first. I have to wait like a second after depressing the clutch before going into first. I just read some info here in the forum. I will try the double pump thing and will also try adjusting the clutch. If that don't work then a trans rebuild will be next in the list of projects for the car.
I also noticed the clutch to be heavy or stiff. Sorry trying to explain it to the best of my knowledge. In other words, I really have to press it in while waiting to let go at a stop, to where my leg really gets tired. Is this normal for a 914?
Sorry Mike for the hijacking of this thread.
Mblizzard   Side Shift Adjustment   Mar 3 2013, 06:00 PM
Dr Evil   I am not clear on all of this, it seems as though ...   Mar 3 2013, 08:22 PM
GeorgeRud   Any wear along the linkage from the shift know to ...   Mar 3 2013, 08:26 PM
Mblizzard   Any wear along the linkage from the shift know to...   Mar 4 2013, 04:30 PM
Mblizzard   Dr. evil, OK I think I understand how the adjustm...   Mar 4 2013, 01:27 PM
Kaduku   Mine grinds when I shift too soon into first. I ha...   Mar 4 2013, 01:43 PM
timothy_nd28   FWIW, I had similar issues of not grabbing all gea...   Mar 4 2013, 01:52 PM
Mblizzard   FWIW, I had similar issues of not grabbing all ge...   Mar 4 2013, 04:14 PM
Dr Evil   FWIW, I had similar issues of not grabbing all ge...   Mar 6 2013, 10:00 PM
Jeff Bowlsby   Here is the procedure from the factory manual FWIW   Mar 4 2013, 01:57 PM
Mblizzard   Here is the procedure from the factory manual FWI...   Mar 4 2013, 04:29 PM
r_towle   The shifter adjustment is right if you can get to ...   Mar 4 2013, 02:36 PM
Mblizzard   The shifter adjustment is right if you can get to...   Mar 4 2013, 04:08 PM
worn   Or, it could just be what it is....a 914 that yo...   Mar 4 2013, 04:13 PM
worn   Well, the subtitle of your post says it all: You h...   Mar 4 2013, 04:10 PM
timothy_nd28   I'm pretty sure that this is your problem. I ...   Mar 4 2013, 04:33 PM
poorsche914   Mike - If you get to the point where you would lik...   Mar 4 2013, 04:53 PM
Mblizzard   Mike - If you get to the point where you would li...   Mar 5 2013, 08:16 AM
Mblizzard   You know I never noticed my typo in the title refe...   Mar 6 2013, 07:48 PM
Dr Evil   What I do? :blink: Sorry, I have been busy trying...   Mar 6 2013, 08:21 PM
hot_shoe914   I also have a shifter I will donate to the cause i...   Mar 6 2013, 09:44 PM
Mblizzard   Shoe/Steve, I have encountered some amazing peopl...   Mar 7 2013, 05:46 PM
Mblizzard   Wow a shifter not held together with wire works mu...   Mar 9 2013, 02:11 PM
Dr Evil   Shift it into 2nd (or 3rd), go into the tunnel and...   Mar 9 2013, 04:58 PM
Mblizzard   Dr Evil I read the notes but I guess I did not re...   Mar 9 2013, 06:55 PM
Mblizzard   Update. I implemented Dr Evils directions and now ...   Mar 16 2013, 12:16 PM
timothy_nd28   dump the carb and reinstall the original FI   Mar 16 2013, 12:24 PM
Mblizzard   That is my end game plan to go back to FI. But be...   Mar 16 2013, 01:28 PM
timothy_nd28   Very ironic, I'm just about to list some dual ...   Mar 16 2013, 01:44 PM
poorsche914   Mike, I was wondering if you had had time to get ...   Mar 16 2013, 01:51 PM
Mblizzard   Steve I did install the shifter and even went for ...   Mar 16 2013, 02:21 PM
Dr Evil   Good to hear, Mike :)   Mar 16 2013, 09:09 PM
cary   Subscribe: All my linkage is tight. But I think I...   Apr 2 2013, 05:39 AM
rhodyguy   mike...for that money you can buy correctly refurb...   Apr 2 2013, 08:27 AM
Mblizzard   Kevin I did look long and hard at what you had. Bu...   Apr 2 2013, 03:38 PM
- Lo-Fi Version Time is now: 20th June 2026 - 11:42 AM
