"TRANSZILLA", side shift 914 - 901 build |
mrbubblehead |
Mar 9 2013, 08:15 PM
Twodollardoug Group: Members Posts: 1,155 Joined: 17-December 10 From: calimesa ca. Member No.: 12,492 Region Association: Southern California |
after a couple of months of planning and parts collecting i have finally started my transzilla build. it will using a normal 914 side shift trans, with a few up grades, i will be dialing in the ring and pinion back to spec with this build also.
i laid all the parts out on my assembly table to give you guys an idea of all the parts installed. (IMG:http://www.914world.com/bbs2/uploads_offsite/i722.photobucket.com-12492-1362881754.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i722.photobucket.com-12492-1362881754.2.jpg) |
mrbubblehead |
Mar 10 2013, 06:49 PM
its time to install the main shaft and pinion shaft to the intermediate plate. and install both first gears. and the reverse and idler gear, and torque every thing down. again.
(IMG:http://www.914world.com/bbs2/uploads_offsite/i722.photobucket.com-12492-1362962960.1.jpg) i installed it into the jig and finished the torquing. (IMG:http://www.914world.com/bbs2/uploads_offsite/i722.photobucket.com-12492-1362962961.2.jpg) once i was satisfied everything was in its proper order, the now "gear stack" came out of the jig. i installed the detent hardware and shift rods and back into the jig to adjust the shift forks. (IMG:http://www.914world.com/bbs2/uploads_offsite/i722.photobucket.com-12492-1362962961.3.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i722.photobucket.com-12492-1362962961.4.jpg) |
Lo-Fi Version | Time is now: 6th June 2024 - 09:42 AM |
