| Mblizzard |
Mar 3 2013, 06:00 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,033 Joined: 28-January 13 From: Knoxville Tn Member No.: 15,438 Region Association: South East States |
OK! I searched the board, got Dr Evils notes. Replaced every bushing. Even the firewall bushing and lubed everything well. Studied everything for broken mounts or transmission ears. Read Zen and the Art of Motorcycle Maintenance. Made multiple attempts to adjust and it shifts like crap. I must really suck at this!
I can get first and reverse but every thing is still a mystery. It seems like going from first to second always winds up in 4th. Yes I did the 3rd 2nd alignment sequester by Dr Evil multiple times with the same results. So I must be doing something wrong. (IMG:style_emoticons/default/headbang.gif) Or the shifter is bad. Looking at the shifter it is worn and certainly will require replacement at some point but it seems to be functioning as intended. I guess in the adjustment process I did verify the gears at the transmission but I am confused as how to "adjust to where a gear should be." Also the directions say to secure the shift rod in the tunnel while you tighten the pinch nut. But with the new bushings there is some resistance to movement. Not binding any where just new. So what am I missing? Should I drink while making the adjustments? (IMG:style_emoticons/default/beer3.gif) |
| timothy_nd28 |
Mar 16 2013, 01:44 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,299 Joined: 25-September 07 From: IN Member No.: 8,154 Region Association: Upper MidWest
Very ironic, I'm just about to list some dual weber 40's in the classified section!
Mblizzard Side Shift Adjustment Mar 3 2013, 06:00 PM
Dr Evil I am not clear on all of this, it seems as though ... Mar 3 2013, 08:22 PM
GeorgeRud Any wear along the linkage from the shift know to ... Mar 3 2013, 08:26 PM
Mblizzard
Any wear along the linkage from the shift know to... Mar 4 2013, 04:30 PM
Mblizzard Dr. evil,
OK I think I understand how the adjustm... Mar 4 2013, 01:27 PM
Kaduku Mine grinds when I shift too soon into first. I ha... Mar 4 2013, 01:43 PM
timothy_nd28 FWIW, I had similar issues of not grabbing all gea... Mar 4 2013, 01:52 PM
Mblizzard
FWIW, I had similar issues of not grabbing all ge... Mar 4 2013, 04:14 PM
Dr Evil
FWIW, I had similar issues of not grabbing all ge... Mar 6 2013, 10:00 PM
Jeff Bowlsby Here is the procedure from the factory manual FWIW Mar 4 2013, 01:57 PM
Mblizzard
Here is the procedure from the factory manual FWI... Mar 4 2013, 04:29 PM
r_towle The shifter adjustment is right if you can get to ... Mar 4 2013, 02:36 PM
Mblizzard
The shifter adjustment is right if you can get to... Mar 4 2013, 04:08 PM
worn
Or, it could just be what it is....a 914 that yo... Mar 4 2013, 04:13 PM
worn Well, the subtitle of your post says it all: You h... Mar 4 2013, 04:10 PM
timothy_nd28 I'm pretty sure that this is your problem. I ... Mar 4 2013, 04:33 PM
poorsche914 Mike - If you get to the point where you would lik... Mar 4 2013, 04:53 PM
Mblizzard
Mike - If you get to the point where you would li... Mar 5 2013, 08:16 AM
Mblizzard You know I never noticed my typo in the title refe... Mar 6 2013, 07:48 PM
Dr Evil What I do? :blink:
Sorry, I have been busy trying... Mar 6 2013, 08:21 PM
hot_shoe914 I also have a shifter I will donate to the cause i... Mar 6 2013, 09:44 PM
Mblizzard Shoe/Steve,
I have encountered some amazing peopl... Mar 7 2013, 05:46 PM
Mblizzard Wow a shifter not held together with wire works mu... Mar 9 2013, 02:11 PM
Dr Evil Shift it into 2nd (or 3rd), go into the tunnel and... Mar 9 2013, 04:58 PM
Mblizzard Dr Evil I read the notes but I guess I did not re... Mar 9 2013, 06:55 PM
Mblizzard Update. I implemented Dr Evils directions and now ... Mar 16 2013, 12:16 PM
timothy_nd28 dump the carb and reinstall the original FI Mar 16 2013, 12:24 PM
Mblizzard That is my end game plan to go back to FI. But be... Mar 16 2013, 01:28 PM
poorsche914 Mike,
I was wondering if you had had time to get ... Mar 16 2013, 01:51 PM
Mblizzard Steve I did install the shifter and even went for ... Mar 16 2013, 02:21 PM
Dr Evil Good to hear, Mike :) Mar 16 2013, 09:09 PM
cary Subscribe:
All my linkage is tight. But I think I... Apr 2 2013, 05:39 AM
rhodyguy mike...for that money you can buy correctly refurb... Apr 2 2013, 08:27 AM
Mblizzard Kevin I did look long and hard at what you had. Bu... Apr 2 2013, 03:38 PM![]() ![]() |
Lo-Fi Version | Time is now: 20th June 2026 - 11:44 AM |
