> You know those two holes..
stateofidleness
post Mar 16 2013, 05:13 PM
..at the top of the transmission housing where it mates to the engine..
I think I dropped a tin screw in one of those holes (go figure.. (IMG:style_emoticons/default/headbang.gif) )
So now I'm assuming I need to check to make sure cuz I'm sure it'll be a bad day if it did go in there and I don't get it out...
I've never separated a transmission from the engine in the 914. How big of a deal is it? Is anything gonna fly out if I just unbolt all the perimeter bolts around the edge?
sigh...
tomeric914
post Mar 16 2013, 05:18 PM
One Lap of America in a 914!
There's an equally big hole in the bottom of the transmission where it will eventually fall out. Even if it doesn't, I doubt it will do any harm.
Drop 100 screws in there and you may have a problem. (IMG:style_emoticons/default/w00t.gif)
914itis
post Mar 16 2013, 05:45 PM
QUOTE(tomeric914 @ Mar 16 2013, 07:18 PM) *
I agree!
If it's stuck by the throw out bearing or any interior hardware you will notice it right away. The pedal may not depress or clutch will not disengage . If you start it and it drives fine, most likely you will be ok
- Lo-Fi Version Time is now: 14th August 2025 - 07:11 PM
