> Crankshaft endplay
jmargush
post Mar 23 2013, 03:59 PM
I just put my case halves together and after I got everything torqued down I checked the crank and it it spins free.
However the end play seems a little excessive. Haven't measured it yet but guess is it is atleast .125"
Is this due to the distributor drive not being installed yet and/or the flywheel not installed yet either?
Just nervous as this is the first time at building one up.
AE354803
post Mar 23 2013, 04:19 PM
Flywheel has to be installed, you adjust the shims between the flywheel and the crank until you get end play of 0.003-0.005"
or do math, install only the two thicker shims and figure out what size to put in to bring you to 0.003-0.005, then reinstall and measure
jmargush   Crankshaft endplay   Mar 23 2013, 03:59 PM
AE354803   Flywheel has to be installed, you adjust the shims...   Mar 23 2013, 04:19 PM
mrbubblehead   your fine, carry on.   Mar 23 2013, 05:04 PM
Mark Henry   At this point you should have 2 shims (to measure ...   Mar 23 2013, 07:16 PM
jmargush   Thanks guys!   Mar 24 2013, 05:55 AM
eyesright   I just put in my first rebuild too. I decided what...   Mar 24 2013, 07:18 AM
- Lo-Fi Version Time is now: 8th July 2025 - 08:44 PM
