> suspension question
dawg
post Mar 23 2013, 09:19 AM
newbie here
not looking for judgement or opinions, just simple question about koni front strut housings and what inserts fit
koni obviously, but what about
kyb g series
blistein
other?
brant
post Mar 24 2013, 08:46 AM
I didn't think the SC series had koni struts....
maybe koni inserts but not struts
the SC's and Carrera's did have 3.5 spacing but I thought they all came with Boge or something struts
I though the actual koni struts were roughly from about 1970- to 1976-ish years
and only an option on those years (S caliper option)
versus the standard strut with 3inch spacing
John's pictures show the difference well
you can see how the housing becomes larger on the koni just above the mounting point for the spindle... on the others it is the same tube size.
this is why you don't see koni struts with spindle mounting location modifications (the taper)
I run koni struts which are sectioned for a drop
but then race shocks inside to accomodate the modification and give travel to a lowered car.
check the shape of the struts on your car
dawg   suspension question   Mar 23 2013, 09:19 AM
bulitt   newbie here not looking for judgement or opinion...   Mar 23 2013, 09:51 AM
brant   kyb's have cruddy valving for this weight of a...   Mar 23 2013, 09:59 AM
Mblizzard   Eric gave some good guidance in http://www.914worl...   Mar 23 2013, 07:33 PM
jmill   Are you talking stock 914 struts or 911 struts whi...   Mar 23 2013, 08:09 PM
dawg   Are you talking stock 914 struts or 911 struts wh...   Mar 24 2013, 07:40 AM
Eric_Shea   If they are truly 911 Koni struts then only Koni i...   Mar 24 2013, 08:03 AM
dawg   If they are truly 911 Koni struts then only Koni ...   Mar 24 2013, 08:14 AM
brant   I didn't think the SC series had koni struts.....   Mar 24 2013, 08:46 AM
Eric_Shea   It's all about the thread pattern on the inser...   Mar 24 2013, 10:40 AM
dawg   OK, it is out of an older 911... (74-77) Part nu...   Mar 24 2013, 03:23 PM
brant   OK, it is out of an older 911... (74-77) Part n...   Mar 24 2013, 05:20 PM
Eric_Shea   http://www.porsche.com/all/media/pdf/origi..._77_K...   Mar 24 2013, 03:45 PM
SKL1   Just got Koni sport inserts for my '73 I'm...   Mar 24 2013, 07:40 PM
dawg   Made by Koni is stamped on them. Hard to determin...   Mar 24 2013, 07:46 PM
Eric_Shea   Do you want to sell them? I have something your K...   Mar 24 2013, 07:51 PM
brant   you are going to have to use koni inserts... if t...   Mar 24 2013, 08:04 PM
dawg   Going to keep the struts, thanks for the interests...   Mar 24 2013, 09:09 PM
brant   maybe they would work since everything measures th...   Mar 24 2013, 10:20 PM
dawg   maybe they would work since everything measures t...   Mar 25 2013, 11:26 AM
- Lo-Fi Version Time is now: 1st July 2025 - 02:21 PM
