New Hoosiers and my suspension, What is going on? |
ww914 |
Mar 23 2013, 07:46 PM
914 Convert Group: Members Posts: 435 Joined: 29-September 11 From: Central Coast, CA Member No.: 13,621 Region Association: Central California |
Today at the track, with my new Hoosier A6's, I was lifting the inside front tire. I had installed 180 lb springs, took off the rear sway bar and tightened up the front 19mm Tarrett just a little. Everyone at the track told me that I needed beefier springs in the back. Well, I have 220 lbs springs, shall I try them? Shall I leave the sway bar off? Should I soften or tighten the front sway bar? Oh, I am running 205/15 on 5.5 rims. I am looking at 7" rims to get the patch better. Any other recommendations?
Woody |
Mar 26 2013, 06:06 AM
Sandbox Rabblerouser and head toilet scrubber Group: Members Posts: 3,858 Joined: 28-December 10 From: San Antonio Texas Member No.: 12,530 Region Association: Southwest Region |
If the back end is loose you need to stiffen up the front. If the car plows you need to stiffen the rear. I'd toss the rear swaybar unless you have a limited slip differential.
Lo-Fi Version | Time is now: 1st June 2024 - 07:40 PM |
