A few questions after more teardown |
stateofidleness |
Mar 27 2013, 12:20 AM
Senior Member Group: Members Posts: 810 Joined: 1-September 07 From: Canyon Lake, Texas! Member No.: 8,065 Region Association: None |
Gents,
Starting to get to the rust repair stages and getting more "intimate" with the engine compartment and removal of fuel line stuff. I took a lot of pictures and have some questions you experienced guys may be able to help me with. 1) I noticed this "bracket" thing that the clutch cable runs through at the firewall. it does NOT appear to be stock as it looks like a washer welded to a piece of metal bent to the correct contour. It's then screwed in to through the floor. What the hell is this? Should I remove it or leave it alone? 2) Pulled the tank and was REALLY happy with how clean it was underneath. Noticed these markings on the tank and was just curious is a) these are factory markings and b) if not factory, does it mean my tank is not original to the car? My car is a '73 and the marking says '72. 3) Anyone know a part number for the black part in this picture, or know where to order a replacement? I've never seen one before.. ever! It was on top of the gas tank and the metal straps went through it. I imagine someone broke it while strapping the tank in at some point. 4) Last question (IMG:style_emoticons/default/cheer.gif) Does this fuel pump bracket look "right"? It's tucked up under the hell hole side engine shelf right next to the factory fuel filter mount. Something just doesn't look right to me with it like it was added by a PO or something. How hard is it to relocate the pump to the front? Any benefit in doing this or leave it where it is? |
JeffBowlsby |
Mar 27 2013, 06:28 PM
914 Wiring Harnesses Group: Members Posts: 8,524 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Is this area a hole into the topside of the engine tin? It should be solid sheet metal here. It should look like the bottom photo.
Attached image(s) |
jdlmodelt |
Mar 27 2013, 08:48 PM
James D. Lane Group: Members Posts: 345 Joined: 30-November 12 From: Colorado Member No.: 15,210 Region Association: Southwest Region |
Lo-Fi Version | Time is now: 1st June 2024 - 06:58 PM |
