> Ready to Remove Back Pad to Change Seatbelt, ........But
Kaduku
post Mar 28 2013, 11:37 PM
Before I go on, I must say that compared to my MGBs, removing the seats were so freakin easy. I have owned BMWs and Mercedes Benzs for many years, but I have only realized how smart these Germans are when it comes to engineering.
So I am ready o remove the back pad. I know that after removing the screws in the bottom, I must lift up and out to get the back pad out. I must also disconnect the vanity light connection, but what about the lid release knob?
ejm
post Mar 29 2013, 04:00 AM
I can see the light at the end of the tunnel
QUOTE(Kaduku @ Mar 29 2013, 01:37 AM) *
The tabs on the back pad slide up into the brackets on the firewall. To get the pad off pull the bottom of the pad forward so you can slide the back pad down.
type47
post Mar 29 2013, 07:20 AM
Viermeister
Kaduku   Ready to Remove Back Pad to Change Seatbelt   Mar 28 2013, 11:37 PM
ndfrigi   Before I go on, I must say that compared to my MG...   Mar 28 2013, 11:53 PM
914socal   Before I go on, I must say that compared to my MG...   Mar 28 2013, 11:57 PM
ejm   I know that after removing the screws in the bot...   Mar 29 2013, 04:00 AM
type47   .   Mar 29 2013, 07:20 AM
The Cabinetmaker   . Interesting post Jim. :poke: :evilgrin:   Mar 29 2013, 08:43 AM
JawjaPorsche   Stating the obvious: You will need to remove your...   Mar 29 2013, 06:19 AM
SUNAB914   Make sure you label your seatbelts (L&R) and d...   Mar 29 2013, 06:20 AM
rpmmaxxed   Make sure you label your seatbelts (L&R) and ...   Mar 29 2013, 06:28 AM
Kaduku   I did not know I had to remove the center tray too...   Mar 29 2013, 08:03 AM
The Cabinetmaker   Not necessary to remove seat belts to remove backp...   Mar 29 2013, 08:45 AM
Kaduku   Not necessary to remove seat belts to remove back...   Mar 29 2013, 09:13 AM
Valy   I hope you're not trying to install retractabl...   Mar 29 2013, 11:38 AM
Kaduku   I hope you're not trying to install retractab...   Mar 29 2013, 11:45 AM
The Cabinetmaker   All good.   Mar 29 2013, 12:14 PM
Kaduku   HELP.......... okay got everything off. How do I g...   Mar 29 2013, 07:11 PM
Dave_Darling   It has to be vertical, like it would be in the car...   Mar 29 2013, 09:36 PM
Kaduku   It has to be vertical, like it would be in the ca...   Mar 29 2013, 10:30 PM
CG-914   :hijacked: Removed the back pad before and everyt...   Mar 29 2013, 09:51 PM
- Lo-Fi Version Time is now: 5th November 2026 - 08:00 PM
