florida 914 |
Newbie ![]() Group: Members Posts: 29 Joined: 29-September 10 From: Salem, OR Member No.: 12,227 Region Association: Pacific Northwest ![]() |
I have a 76 x19 2.0 with starter issues. The starter does not disengage unless the key is completely off (the intermediate, accessories position does not work -- it's either starting, or nothing). On the advice of the other forum, I tried pulling the yellow wire off once started, and it runs fine then. Supposedly that meant it was the ignition switch, but when I replaced it the problem persisted. So then I was told the starter solenoid was bad, so I replaced the starter. Still the same. I then tried a second new switch in the hopes that the first one was merely defective, but it's still the same issue.
Any ideas? Thanks! |
florida 914 |
Oops: "x19" is a typo. I meant x19.
I have a 76 x19 2.0 with starter issues. The starter does not disengage unless the key is completely off (the intermediate, accessories position does not work -- it's either starting, or nothing). On the advice of the other forum, I tried pulling the yellow wire off once started, and it runs fine then. Supposedly that meant it was the ignition switch, but when I replaced it the problem persisted. So then I was told the starter solenoid was bad, so I replaced the starter. Still the same. I then tried a second new switch in the hopes that the first one was merely defective, but it's still the same issue. Any ideas? Thanks! |
Lo-Fi Version | Time is now: 22nd September 2025 - 09:12 PM |
