| rpmmaxxed |
Apr 2 2013, 01:39 PM
Member ![]() ![]() Group: Members Posts: 387 Joined: 24-May 05 From: Oceanside, CA Member No.: 4,140 Region Association: Southern California |
While removing my Kerry Hunter header to install copper gaskets, I discovered 3 of my 4 passenger side tubes were no longer seated fully. I'm sure for most of us, this is routinely checked, but maybe for some of the less knowledgable, including myself, a good reminder.
Attached thumbnail(s) |
| Dave_Darling |
Apr 2 2013, 08:35 PM
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,338 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California
Not a bitch to me. Hook them into the rocker stands (that's why the notch in the stands faces down!) and then push them under the rocker arm ends and pushrods. Then take an L-shaped allen wrench and pull on the part that sticks down into the tube until it is resting on the shoulder of the tube.
--DD |
rpmmaxxed Never know when somethin can rattle loose... Apr 2 2013, 01:39 PM
Vacca Rabite Your pushrod tube keeper spring is either not inst... Apr 2 2013, 01:57 PM
worn
Your pushrod tube keeper spring is either not ins... Apr 2 2013, 02:01 PM
rpmmaxxed
Vacca Rabite
Your pushrod tube keeper spring is either not in... Apr 2 2013, 06:20 PM
brant I agree...
pull the valve cover and check your ret... Apr 2 2013, 01:59 PM
Cap'n Krusty If you need springs, I have 'em.
The Cap... Apr 2 2013, 02:41 PM
02loftsmoor Cap'n do you had some sort of guidance on inst... Apr 5 2013, 09:12 AM
Rand
do you had some sort of guidance on installing th... Apr 5 2013, 12:20 PM
ConeDodger
The Cap... Apr 5 2013, 12:17 PM
rnellums This probably means I have installed mine the easy... Apr 3 2013, 08:48 AM
stugray I just did this last night.
Exactly as Dave D. say... Apr 5 2013, 09:44 AM
stugray Here is how it looks once you feed the spring into... Apr 6 2013, 06:27 PM![]() ![]() |
Lo-Fi Version | Time is now: 30th April 2026 - 08:27 PM |
