| rpmmaxxed |
Apr 2 2013, 01:39 PM
Member ![]() ![]() Group: Members Posts: 387 Joined: 24-May 05 From: Oceanside, CA Member No.: 4,140 Region Association: Southern California |
While removing my Kerry Hunter header to install copper gaskets, I discovered 3 of my 4 passenger side tubes were no longer seated fully. I'm sure for most of us, this is routinely checked, but maybe for some of the less knowledgable, including myself, a good reminder.
Attached thumbnail(s) |
| stugray |
Apr 5 2013, 09:44 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
I just did this last night.
Exactly as Dave D. says above, but I used a hooked dental pick to pull the ends out until they rest on the tubes. You will hear the "Click". I can get pictures of the process later today as I have to put one set of rockers back in tonight. Stu |
rpmmaxxed Never know when somethin can rattle loose... Apr 2 2013, 01:39 PM
Vacca Rabite Your pushrod tube keeper spring is either not inst... Apr 2 2013, 01:57 PM
worn
Your pushrod tube keeper spring is either not ins... Apr 2 2013, 02:01 PM
rpmmaxxed
Vacca Rabite
Your pushrod tube keeper spring is either not in... Apr 2 2013, 06:20 PM
brant I agree...
pull the valve cover and check your ret... Apr 2 2013, 01:59 PM
Cap'n Krusty If you need springs, I have 'em.
The Cap... Apr 2 2013, 02:41 PM
02loftsmoor Cap'n do you had some sort of guidance on inst... Apr 5 2013, 09:12 AM
Rand
do you had some sort of guidance on installing th... Apr 5 2013, 12:20 PM
ConeDodger
The Cap... Apr 5 2013, 12:17 PM
Dave_Darling Not a bitch to me. Hook them into the rocker stan... Apr 2 2013, 08:35 PM
rnellums This probably means I have installed mine the easy... Apr 3 2013, 08:48 AM
stugray Here is how it looks once you feed the spring into... Apr 6 2013, 06:27 PM![]() ![]() |
Lo-Fi Version | Time is now: 30th April 2026 - 07:23 PM |
