| draganc |
Apr 6 2013, 07:07 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 725 Joined: 2-November 09 From: central new jersey Member No.: 11,000 Region Association: North East States |
Annoyed by the thread "What have you done to your 914 today" I started working on my car again.
Just below the left jack post, it appears that one of the PO must have "hooked" the car on the long - resulting in a rip and rust, about 4-5 inches long: ![]() The surrounding area appears to be very solid, beside the lower part of the jack support, which I removed and will replace with a new piece: ![]() ![]() ![]() ![]() Once I cut the floor pan to gain access to the long, I found that the inner c-shaped metal was thin and rusted. I cut all the way into solid metal to gain access for inspection and cleaning. ![]() ![]() My approach is to "wash" out the area with Ospho, "flush" the long, up and down, with Eastwood's Internal Frame Coating, apply some weldable primer and patch up the rusted/removed area with some new metal. ![]() ![]() I have already installed inside the engine bay Heim-Rod-Braces from Tangerine racing (before cutting) and intend to install as well a long-stiffening kit from Maddog - once this repair is done and the car back on it's wheel. The car is very sold for it's age, when jacked-up by the rear donuts, the door gaps are the same as on the ground - with or without the top on. The rust-like color on the floor is Arizona sand/dust that just wipes off. It will be a street car only. Here is the big questions: Should I try to patch up the inner c-shaped sheet metal (about 1.5 x 4") and if yes what are your suggestions? Or am I over thinking this patch with the Heim-rods installed and the long kit to be. Thanks for your inputs, Dragan PS: What is the purpose of the c-shaped sheet-metal anyways, heat shield or structural? |
| cary |
Apr 7 2013, 10:03 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,900 Joined: 26-January 04 From: Sherwood Oregon Member No.: 1,608 Region Association: Pacific Northwest
Oh yeah,
I don't claim to be an expert. Just a DIY'r. Started my life as a Time Study Engineer at an assembly plant. So its always been, how come and why for. |
draganc Driver long repair - open to suggestions Apr 6 2013, 07:07 PM
bandjoey Look under Restoration and Rebuild threads. You... Apr 6 2013, 07:39 PM
draganc
Look under Restoration and Rebuild threads. You... Apr 6 2013, 08:11 PM
cary Based on what I know now. Stop cutting .............. Apr 7 2013, 09:27 AM
cary I would follow Jeff Hail's lead on this sectio... Apr 7 2013, 09:56 AM
draganc Thanks for the links and great work Cary! Apr 7 2013, 03:48 PM![]() ![]() |
Lo-Fi Version | Time is now: 6th March 2026 - 11:37 PM |
