| PanelBilly |
Apr 6 2013, 04:46 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,954 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest
This is one of the jobs I never finished. I installed new rubber squeegies in the doors and when I operate the windows, they pull out. Tried a little glue, but it doesn't hold. Any ideas
Here's how I did it. First, Mark sent me a new set of them and they look more pronounced if I can use that term. I worked the metal some more. It was a bit bent up. Then I slid the rubber in with the help of a little soap. Lastly, I use a set of pliers that had been modified for pulling plug wires. They were perfect because then crimped the edge of the metal without touching the rubber. |
| rhodyguy |
Apr 7 2013, 10:13 AM
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,252 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
i guess he could wash his hands but why would he need to? you might think your windows are clean. a little windex and paper towel isn't going to do the job. the sharp edge will drag on accumulated grime that may fold the edge under and out it pops due friction. the glass should be slick. or don't try really cleaning, run a fat bead of silicon in the channel and call it a day.
k |
PanelBilly Can't keep the rubber squeegie in place Apr 6 2013, 04:46 PM
Cupomeat GREAT! :agree:
I have never been able to fi... Apr 6 2013, 05:44 PM
messix does the channel that the rubber fit in to need to... Apr 6 2013, 05:55 PM
r_towle Mine were preened over on each end Apr 6 2013, 06:03 PM
kg6dxn I got new ones from 914 rubber. Mine pull out in t... Apr 6 2013, 10:54 PM
zonedoubt Put some talcum powder on them. Apr 6 2013, 11:50 PM
rhodyguy clean the windows with a diluted vinegar/ammonia s... Apr 7 2013, 06:54 AM
balljoint Should he wash his arm and put glycerin on his shi... Apr 7 2013, 07:37 AM
76-914 Well, I feel strange. I've done them on both m... Apr 7 2013, 08:10 AM
balljoint
Well, I feel strange. I've done them on both ... Apr 7 2013, 09:19 AM
76-914
Well, I feel strange. I've done them on both... Apr 7 2013, 09:37 AM
Daiberl I have the same problem with my rubber seal, reall... Apr 7 2013, 09:26 AM
PanelBilly
I have the same problem with my rubber seal, real... Apr 7 2013, 02:22 PM
Mikey914 Let me know if you are having issues. I'd be h... Apr 7 2013, 09:51 AM
Mikey914 Don't glue them, it would be a mess.
Thx Apr 7 2013, 09:51 AM
Daiberl
Thx
Ok,... Apr 7 2013, 09:56 AM
76-914
Thx
Ok... Apr 7 2013, 10:19 AM
Daiberl
[quote name='Daiberl' post='1846507' date='Apr 7 ... Apr 7 2013, 10:35 AM
rhodyguy when you guys installed these did you remove the e... Apr 7 2013, 03:15 PM
MrHyde I'm having the same issue with one of my squee... Apr 7 2013, 04:05 PM
rhodyguy post #7 Apr 7 2013, 05:07 PM
MrHyde Tryed that already Apr 7 2013, 05:27 PM
PanelBilly
Here's the pliers Apr 14 2013, 10:07 AM![]() ![]() |
Lo-Fi Version | Time is now: 16th April 2026 - 04:14 PM |
