| mepstein |
Apr 8 2013, 10:25 AM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,907 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
I'm trying to get the engine bolted back in the car. The trans mounts are bolted in. I have a jack under each end of the engine bar holding the engine into the body. Problem is, the bolts that go up through the engine bar and engine mount on the body aren't long enough. ??? They were the right size when I dropped the engine and I didn't mix them up with other bolts. I need another inch of threads. Help please.
| mepstein |
Apr 8 2013, 11:41 AM
Fixed. I had added a washer to the head of the bolt were there shouldn't have been one. The bolt needs to recess into the crossbar. I got my extra inch and mounts bolted up easily. Thanks everyone for putting up with my - duh - moment.
mepstein fixed - Engine re-install help Apr 8 2013, 10:25 AM
SLITS If they are the same bolts, you don't have the... Apr 8 2013, 10:33 AM
mepstein If they are the same bolts, you don't have the... Apr 8 2013, 10:42 AM
type47
...The bolts go down from the mount .... the nuts... Apr 8 2013, 10:46 AM
914itis Something is not sitting properly . The bolts goes... Apr 8 2013, 10:52 AM
JRust
Fixed. I had added a washer to the head of the bo... Apr 8 2013, 01:06 PM![]() ![]() |
Lo-Fi Version | Time is now: 16th September 2026 - 01:44 PM |
