| ndfrigi |
Apr 7 2013, 11:19 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,980 Joined: 21-August 11 From: Orange County Member No.: 13,474 Region Association: Southern California
Hi guys,
I just saw the postings on recent trip from 66 route and it was mentioned that there are few joined the event with 4 cylinder engine. My question is, how reliable is it for a long drive/trip with just a stock set up engine without modification in the cooling system? Or does it need modification in the cooling system and what are those items? My car is a 1975 1.8 FI. Thank you and God Bless! http://www.914world.com/bbs2/uploads/post-...92529_thumb.jpg |
| rick 918-S |
Apr 8 2013, 10:28 AM
Hey nice rack! -Celette ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 21,258 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region
Shouldn't be an issue if the underside of the tin isn't filled with debris and all the fins on the cooling fan are intact. This is an issue we see with cars that sit outside (or in storage for that matter) for long periods of time. Mice and squirrels will get into the cooling system and build nests. If your car fits the description remove the engine, remove the tin and check it out. Also check the bellows that operates the cooling flaps. If it fails the engine defaults in the open position so overheating is less of an issue but it effects warm up.
A stock engine in good tune, properly functioning injection or carbs with a proper valve adjustment and clean oil should not have an issue with cooling. |
| ndfrigi |
Apr 8 2013, 02:17 PM
Shouldn't be an issue if the underside of the tin isn't filled with debris and all the fins on the cooling fan are intact. This is an issue we see with cars that sit outside (or in storage for that matter) for long periods of time. Mice and squirrels will get into the cooling system and build nests. If your car fits the description remove the engine, remove the tin and check it out. Also check the bellows that operates the cooling flaps. If it fails the engine defaults in the open position so overheating is less of an issue but it effects warm up. A stock engine in good tune, properly functioning injection or carbs with a proper valve adjustment and clean oil should not have an issue with cooling. Yes all fins on the fan are complete but for the bellow that operates the flaps is no longer installed which the flaps are in open positions. It just need at least 5 to 10 mins. running to warm up the engine. Well the only thing I was not able to do is to adjust the valve and maybe replace the tunnel fuel lines which is still original. thanks again sir! |
| ThePaintedMan |
Apr 8 2013, 02:20 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,887 Joined: 6-September 11 From: St. Petersburg, FL Member No.: 13,527 Region Association: South East States
Yes I all fins on the fan are complete but for the bellow that operates the flaps is no longer installed which the flaps are in open positions. It just need at least 5 to 10 mins. running to warm up the engine. Well the only thing I was no able to do is to adjust the valve and maybe replace the tunnel fuel lines which is still original. thanks again sir! Those are two things you should strongly consider doing before you drive it anywhere, especially long distances. |
| ndfrigi |
Apr 8 2013, 02:24 PM
Yes I all fins on the fan are complete but for the bellow that operates the flaps is no longer installed which the flaps are in open positions. It just need at least 5 to 10 mins. running to warm up the engine. Well the only thing I was no able to do is to adjust the valve and maybe replace the tunnel fuel lines which is still original. thanks again sir! Those are two things you should strongly consider doing before you drive it anywhere, especially long distances. thanks for both responses! |
ndfrigi 914 with 4 cylinder stock set up in long trip Apr 7 2013, 11:19 PM
rick 918-S Drive it like ya stole it. Iffen it breaks fix it ... Apr 7 2013, 11:37 PM
ndfrigi
Drive it like ya stole it. Iffen it breaks fix it... Apr 8 2013, 10:17 AM
McMark Rode in a 4 cylinder from San Francisco to Moab UT... Apr 8 2013, 01:03 AM
ndfrigi
Rode in a 4 cylinder from San Francisco to Moab U... Apr 8 2013, 10:18 AM
JamesM Provided everything is good on your engine/ignitio... Apr 8 2013, 10:29 AM
ThePaintedMan
When running properly I think these cars are a l... Apr 8 2013, 10:39 AM
damesandhotrods You should see the mileage the bus crowd racks up ... Apr 8 2013, 11:00 AM
ndfrigi
You should see the mileage the bus crowd racks up... Apr 8 2013, 02:21 PM
URY914 I used to drive my 914 10 hours each way to colleg... Apr 8 2013, 02:47 PM
timothy_nd28 Stock cooling for a stock engine should be fine, h... Apr 8 2013, 03:13 PM
ndfrigi
Stock cooling for a stock engine should be fine, ... Apr 8 2013, 03:53 PM
Dave_Darling Counterpoint:
My 914 runs hot. On 90+ days on lo... Apr 8 2013, 03:16 PM
ndfrigi
Counterpoint:
My 914 runs hot. On 90+ days on l... Apr 8 2013, 03:56 PM
ThePaintedMan
Sir Dave, any site or previous posting regarding... Apr 8 2013, 04:48 PM
ndfrigi
Sir Dave, any site or previous posting regardin... Apr 8 2013, 06:19 PM
ndfrigi video of my teen
http://www.youtube.com/watch?v=t... Apr 8 2013, 03:58 PM
Mr. Olympic Blue 2 You If you are going on a long trip in good weather pu... Apr 8 2013, 05:15 PM
ndfrigi
If you are going on a long trip in good weather p... Apr 9 2013, 09:15 PM
Dave_Darling All of your favorite on-line Porsche retailers car... Apr 8 2013, 07:06 PM
ndfrigi
All of your favorite on-line Porsche retailers ca... Apr 9 2013, 10:42 AM
MoveQik
Hi guys,
I just saw the postings on recent trip ... Apr 9 2013, 10:55 AM
ndfrigi
[quote name='ndfrigi' post='1846889' date='Apr 7 ... Apr 9 2013, 01:20 PM
monkeyboy I drive my car all over. If it is running right, t... Apr 9 2013, 11:29 AM
ndfrigi
I drive my car all over. If it is running right, ... Apr 9 2013, 01:21 PM![]() ![]() |
Lo-Fi Version | Time is now: 1st May 2026 - 01:38 PM |
