> 914 with 4 cylinder stock set up in long trip, how reliable is a 914 4 cylinder
ndfrigi
post Apr 7 2013, 11:19 PM
Hi guys,
I just saw the postings on recent trip from 66 route and it was mentioned that there are few joined the event with 4 cylinder engine.
My question is, how reliable is it for a long drive/trip with just a stock set up engine without modification in the cooling system?
Or does it need modification in the cooling system and what are those items?
My car is a 1975 1.8 FI.
Thank you and God Bless!
http://www.914world.com/bbs2/uploads/post-...92529_thumb.jpg
Dave_Darling
post Apr 8 2013, 03:16 PM
914 Idiot
Counterpoint:
My 914 runs hot. On 90+ days on longer-distance trips I would have to stop periodically to let the oil cool down. I'm pretty sure it was over 250F on occasion when I stopped.
I now have an external oil cooler, and temps never got over 240F, even in 100+ weather through the Nevada desert, climbing up hills. The cooler is in a sub-optimal location (under the rear trunk floor) but it still helped.
Charlie Davis out in TX had a 2-liter that always ran hot. He tried a number of experiments to bring down the oil temps. Some had to do with ducting air into the engine bay, others had to do with trying to get air to a poorly-located external cooler.
So there are 914s out there that could do with external coolers.
--DD
ndfrigi
post Apr 8 2013, 03:56 PM
QUOTE(Dave_Darling @ Apr 8 2013, 02:16 PM) *
Counterpoint:
--DD
Sir Dave, any site or previous posting regarding external coolers which I can check?
Thank you sir for the detailed reply!
ThePaintedMan
post Apr 8 2013, 04:48 PM
QUOTE(ndfrigi @ Apr 8 2013, 05:56 PM) *
IMHO, get the car tuned to perfection first. That includes learning how to do a valve lash adjustment, which can greatly impact how hot the car runs.
Then you can move on to finding out what the oil temperature is by installing a good gauge (might consider a quality cylinder head temperature gauge as well.) As Dave mentioned, some engines just run hot, for whatever reason, but most of them cool very well if there aren't a ton of leaves and other obstacles in the path of the air. A gauge is the only way to tell for sure.
Not to keep harping on it, but replacing your fuel lines and the seals should still be at the top of your list (http://www.tangerineracing.com/stainlessfuellines.htm). Chris makes a great set which you can install with the engine in the car. That is, of course, unless you like the "car-B-Q" look.
ndfrigi
post Apr 8 2013, 06:19 PM
QUOTE(ThePaintedMan @ Apr 8 2013, 03:48 PM) *
Thanks a lot! any suggestion of a site where to buy good fuel injector seals?
ndfrigi   914 with 4 cylinder stock set up in long trip   Apr 7 2013, 11:19 PM
rick 918-S   Drive it like ya stole it. Iffen it breaks fix it ...   Apr 7 2013, 11:37 PM
ndfrigi   Drive it like ya stole it. Iffen it breaks fix it...   Apr 8 2013, 10:17 AM
McMark   Rode in a 4 cylinder from San Francisco to Moab UT...   Apr 8 2013, 01:03 AM
ndfrigi   Rode in a 4 cylinder from San Francisco to Moab U...   Apr 8 2013, 10:18 AM
rick 918-S   Shouldn't be an issue if the underside of the ...   Apr 8 2013, 10:28 AM
ndfrigi   Shouldn't be an issue if the underside of the...   Apr 8 2013, 02:17 PM
ThePaintedMan   Yes I all fins on the fan are complete but for t...   Apr 8 2013, 02:20 PM
ndfrigi   Yes I all fins on the fan are complete but for ...   Apr 8 2013, 02:24 PM
JamesM   Provided everything is good on your engine/ignitio...   Apr 8 2013, 10:29 AM
ThePaintedMan   When running properly I think these cars are a l...   Apr 8 2013, 10:39 AM
damesandhotrods   You should see the mileage the bus crowd racks up ...   Apr 8 2013, 11:00 AM
ndfrigi   You should see the mileage the bus crowd racks up...   Apr 8 2013, 02:21 PM
URY914   I used to drive my 914 10 hours each way to colleg...   Apr 8 2013, 02:47 PM
timothy_nd28   Stock cooling for a stock engine should be fine, h...   Apr 8 2013, 03:13 PM
ndfrigi   Stock cooling for a stock engine should be fine, ...   Apr 8 2013, 03:53 PM
Dave_Darling   Counterpoint: My 914 runs hot. On 90+ days on lo...   Apr 8 2013, 03:16 PM
ndfrigi   Counterpoint: My 914 runs hot. On 90+ days on l...   Apr 8 2013, 03:56 PM
ThePaintedMan   Sir Dave, any site or previous posting regarding...   Apr 8 2013, 04:48 PM
ndfrigi   Sir Dave, any site or previous posting regardin...   Apr 8 2013, 06:19 PM
ndfrigi   video of my teen http://www.youtube.com/watch?v=t...   Apr 8 2013, 03:58 PM
Mr. Olympic Blue 2 You   If you are going on a long trip in good weather pu...   Apr 8 2013, 05:15 PM
ndfrigi   If you are going on a long trip in good weather p...   Apr 9 2013, 09:15 PM
Dave_Darling   All of your favorite on-line Porsche retailers car...   Apr 8 2013, 07:06 PM
ndfrigi   All of your favorite on-line Porsche retailers ca...   Apr 9 2013, 10:42 AM
MoveQik   Hi guys, I just saw the postings on recent trip ...   Apr 9 2013, 10:55 AM
ndfrigi   [quote name='ndfrigi' post='1846889' date='Apr 7 ...   Apr 9 2013, 01:20 PM
monkeyboy   I drive my car all over. If it is running right, t...   Apr 9 2013, 11:29 AM
ndfrigi   I drive my car all over. If it is running right, ...   Apr 9 2013, 01:21 PM
- Lo-Fi Version Time is now: 1st May 2026 - 01:39 PM
