> Starter problems, not disengaging
florida 914
post Apr 1 2013, 05:01 PM
I have a 76 x19 2.0 with starter issues. The starter does not disengage unless the key is completely off (the intermediate, accessories position does not work -- it's either starting, or nothing). On the advice of the other forum, I tried pulling the yellow wire off once started, and it runs fine then. Supposedly that meant it was the ignition switch, but when I replaced it the problem persisted. So then I was told the starter solenoid was bad, so I replaced the starter. Still the same. I then tried a second new switch in the hopes that the first one was merely defective, but it's still the same issue.
Any ideas?
Thanks!
florida 914
post Apr 9 2013, 07:08 AM
For the record, this ended up being a bad ECM relay -- a very odd culprit, since the car was long ago converted to carbs. Somehow the burned-out relay was messing up the works. I'll say it for the thousandth time: I do not understand electricity.
- Lo-Fi Version Time is now: 22nd September 2025 - 09:12 PM
