Harpo |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,304 Joined: 21-August 11 From: Motor City aka Detroit Member No.: 13,469 Region Association: None ![]() |
Good morning everyone
For those of you with adjustable perches on your rear shocks where did you get them? What size springs did you use? I know that Paragon has them and Koni shocks are on sale Thanks David |
ww914 |
914 Convert ![]() ![]() Group: Members Posts: 435 Joined: 29-September 11 From: Central Coast, CA Member No.: 13,621 Region Association: Central California ![]() |
Good morning everyone For those of you with adjustable perches on your rear shocks where did you get them? What size springs did you use? I know that Paragon has them and Koni shocks are on sale Thanks David Got mine at Ground Control Systems, Inc. They are fairly priced and work good. I got the 225 lb springs. Not sure how they are going to work on the street as I got them for AX. ![]() ![]() |
draganc |
Senior Member ![]() ![]() ![]() Group: Members Posts: 725 Joined: 2-November 09 From: central new jersey Member No.: 11,000 Region Association: North East States ![]() |
Good morning everyone For those of you with adjustable perches on your rear shocks where did you get them? What size springs did you use? I know that Paragon has them and Koni shocks are on sale Thanks David Got mine at Ground Control Systems, Inc. They are fairly priced and work good. I got the 225 lb springs. Not sure how they are going to work on the street as I got them for AX. ![]() ![]() WW914, can you pls do me a favor? I have the same setup from ground control but with 125lbs springs and are trying to dial in the perch setting. Questions: 1) how long is your spring 2) what position do you have the perch clip and 3) and do you have a pic of your car on the ground respectively how much space to you have between your rubber and body? Thanks buddy! |
Lo-Fi Version | Time is now: 9th July 2025 - 12:30 PM |
