| Jgilliam914 |
Apr 11 2013, 07:34 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,375 Joined: 30-July 12 From: Iowa / Florida Member No.: 14,732 Region Association: Upper MidWest |
After seeing all the work people have done to make their cars as rust free as possible. I decided to do my part. The rear trunk floor pan was " repaired " when I got the flares installed 28 years ago. I thought the body man had removed the original metal and replaced it with a flat piece just slightly above it. When in reality he just welded a piece over the top and left the original pan in place. Although it has stayed dry for these past few years I couldn't allow myself to continue without tearing out the original and the " fix ". So today I get the replacement part from restoration design and have it 90% installed and welded up.
The question I have is the heat shield. Is it needed to provide it's original use to keep heat out of the trunk or is it added weight? |
| Jeff Hail |
Apr 11 2013, 10:29 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,141 Joined: 3-May 07 From: LA/ CA Member No.: 7,712 |
Go find a wrecked late model Nissan Altima, Honda or Mercedes. Above the muffler you will find these two ply aluminum honeycomb heat shields. Same length as the 914 and about 2 inches wider. Only weights 9 oz compared to the factory heat shield boat anchor. Weld or bolt some 1 inch standoffs under the floor and you have a trick shield and lose some weight. Mercedes uses them just behind the qtr panels and they cost about $28.00 -they are formable.
993's and 996's uses the same material attached to the rear bumper reinforcements to keep the bumper cover from melting. Attached image(s)
| 76-914 |
Apr 12 2013, 09:54 AM
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,880 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California
Go find a wrecked late model Nissan Altima, Honda or Mercedes. Above the muffler you will find these two ply aluminum honeycomb heat shields. Same length as the 914 and about 2 inches wider. Only weights 9 oz compared to the factory heat shield boat anchor. Weld or bolt some 1 inch standoffs under the floor and you have a trick shield and lose some weight. Mercedes uses them just behind the qtr panels and they cost about $28.00 -they are formable. 993's and 996's uses the same material attached to the rear bumper reinforcements to keep the bumper cover from melting. That's a Hell of a fine idea. And the OG shield is heavy. |
Jgilliam914 Rear trunk floor pan installation Apr 11 2013, 07:34 PM
914Sixer A BIG YES ! Keep the heat shield. Apr 11 2013, 07:38 PM
JimN73 the heat shield deflects a phenomenal amount of he... Apr 11 2013, 08:03 PM
worn
the heat shield deflects a phenomenal amount of h... Apr 11 2013, 09:18 PM
Black22 The PO of my car cut the heat shield in half for a... Apr 11 2013, 09:25 PM
Spoke I removed the heat shield to repair the trunk floo... Apr 12 2013, 03:42 AM
rudedude my 70 4 cyl never had one, the 6 does. Did karmann... Apr 12 2013, 08:10 AM
914Sixer Most of the early 70's year model 4 and 6 had ... Apr 12 2013, 08:14 AM
mepstein Any idea how much one really weighs? Apr 12 2013, 11:37 AM
Krieger Mine has been gone for years. No problems, but no... Apr 12 2013, 11:49 AM
Jeff Hail I just tossed a rusty one in the trash. More like ... Apr 12 2013, 11:57 AM![]() ![]() |
Lo-Fi Version | Time is now: 29th April 2026 - 09:14 PM |
